Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Unread 19-09-2010, 17:36
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
pic: Staged Double Vertical Suspension
Unread 19-09-2010, 17:38
Basel A's Avatar
AKA: @BaselThe2nd
Re: pic: Staged Double Vertical Suspension
(For those interested, there's a few more pictures at the end of this album, and I can also upload the plans of the vertical suspenders themselves)
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 19-09-2010, 17:40
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
When did you guys actually put the vertical hangers on?
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 19-09-2010, 17:45
Basel A's Avatar
AKA: @BaselThe2nd
We put them on Wednesday night, but when we found out that our schedule didn't have 33, you guys (27), or 1718 in it, we took them off until after the event, when this took place.
-Paul Copioli
Unread 19-09-2010, 20:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Forget the staged part; this is quite impressive. Good job!
GitHub
Unread 20-09-2010, 01:13
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Staged or not, that is quite awesome.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 20-09-2010, 22:39
Basel A's Avatar
AKA: @BaselThe2nd
Thanks! I'd like to note that when I was hanging, there was about 500 pounds all on our two solid aluminum hooks, and there's nary a dent. In retrospect, that would've been a good spot for some lightening holes.
-Paul Copioli
Unread 20-09-2010, 23:10
Chris is me's Avatar
AKA: Pinecone
Those side hanger attachments look very, very bent. Did the mechanism take the loads well? Would it have worked repeatedly?
Unread 20-09-2010, 23:26
Basel A's Avatar
AKA: @BaselThe2nd
The one on the left was not bent at all.
The one on the right, however, is. That happened when 1718 suspended. I suspect is was because their mechanism was a bit too tall, but it could have just been a moment-exertion issue.
I will note that while it bent, it did not break. Even after 1718 was removed, 27 suspended successfully without any further bending.
Would it have worked repeatedly? I am inclined to say yes, but really I'm not sure. As I said, there was another suspension without further bending. That specific bend may have been a "freak" incident or just a result of 1718's mechanism.
I do believe it would have worked multiple times in usage with 27, 33, and most other "strongman" vertically hanging robots. It was never tested with "driving up" 'bots such as 2056.
-Paul Copioli
Unread 21-09-2010, 16:31
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
Actually I think it happened because our bumper hung up on your bumper momentarily, and when it released there was a jolt which caused the bend. This is just a guess, but I think if we had lifted smoothly, instead of catching bumpers, the bend wouldn't have happened. I was a little nervous when it initially happened, but Clint was yelling to keep lifting so we did. It was pretty impressive to see - would've been really great to see during a match!
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
pic: Robot suspension joeweber Extra Discussion 11 15-01-2010 20:32
pic: Air Suspension joeweber Extra Discussion 23 30-12-2009 13:04
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
