Go to Post I'll try to sum up the icon and compile thing quickly so as not to interrupt the design of SkyNet. - Greg McKaskle [more]
Unread 12-09-2010, 22:17
mom1155's Avatar
mom1155 mom1155 is offline
NYC Regional Planning Committee
AKA: Cherrie Fleisher-Strauss
mom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to allmom1155 is a name known to all
Bag & Tag: What were the best practices?
Just wondering what the best practices & pitfalls were for Bag & Tag. What worked & what was problematic last year? If there is already a thread on this, please direct me to it.
Unread 13-09-2010, 06:38
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Bag & Tag: What were the best practices?
Remove the bumpers from the robot prior to bagging and bag them separately. If the bumpers are still on it becomes difficult to navigate doorways and such. Bagging the bumpers detached, but with the robot, just adds complexity as they shift around.
Mark
Brick walls are for other people. - Randy Pausch
Unread 13-09-2010, 08:24
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
For the 2009, there were unlimited times you could open the bag, but the bag could only be open for 8 hrs during the week of a district event. For 2010, it was minimized to 6 hours with a minimum of a 2 hour block. planning an prioritizing "un-bag" time became a very important aspect to the bag and tag process (if you need to make repairs or improvements). This was a very interesting learning opportunity. Have a planned schedule, and have a timer of some sort set to intervals.
Unread 13-09-2010, 10:08
Many teams forget/lose track of their paperwork. There just is not enough emphasis put on the log for bag and tag. However, it becomes more complicated for the teams that don't expect to go on to Champs, have gone through a difficult weekend at a district event and the bag and tag becomes a last minute item for the team and event LRI.
Unread 13-09-2010, 15:18
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
We bagged the bot and put it on a small hand cart.
It can be tricky to maneuver the bot by hand when it's in the bag....tough to get a hand hold sometimes.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 13-09-2010, 17:22
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
the bag is very slick and if you robot is to maximum dimensions it is even harder to grab on to. Take the off any side plates that might be on I would the robot so you can get a better grip if you can't reach under your robot in the bag. cover any "sharp" edges (points or other small ended structure) that may cut into the bag. Pool noodles work great for that. Keep the bumpers off. It is really bad when you are on your way to competition but can't get your robot out of the build room because the bumpers are on and you are too big for the door. When putting the robot in the bag open it all the way and fold/roll down the sides. then pick up the robot and set it on top of the bag and roll the sides up. It makes it much easier when your robot is really tall and need to use the whole bag. Take all your tools and batteries off the robot so you can put them away and charge them. this also allows you to weigh the robot while it is the bag so you can see what you have to do in you un-bagging time. I like the bag and tag system. The only big problem is what to transport it in. I transported it last year in the back of my Ford Explorer but if no one has a big car to put it in there might be a small problem.
Unread 14-09-2010, 12:36
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Please note: Unbagging only applied to Friday-Saturday Michigan District events. If your bag-n-tag event includes a Thursday practice day you do not get the 8 hour un-bag allowance.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 20-09-2010, 23:08
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
As a Michigan team, we've been dealing with bagging for 2 years, and the truth is, it's easier to bag it than to put it in the crate. Just remember:
A) place bag on floor, robot on top of bag. Have at least 2 people lift the bag walls.
B) remove bumpers. These make bagging more difficult. If your robot has an enclosed inner space, such as many Lunacy robots, the bumpers may fit inside.
C) Try to avoid cuts and snags on the bag as it is lifted.
D) When transporting, lift by the robot, not by the bag.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 21-09-2010, 11:03
kramarczyk's Avatar
Don't forget to remove the battery from the robot prior to bagging. It makes the robot lighter and you charge the battery a lot easier.
Mark
Unread 21-09-2010, 11:52
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
If I remember correctly, a certain Canadian team learned to not stuff too much into their bag. They had a lot of trouble getting through the door way at one of the competitions.
And.. If I also remember correctly, they owe me a t-shirt for helping.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 21-09-2010, 21:30
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
We actually put our robot on a board that had two 2x4s on the bottom, which kept the board off the ground. The board had four holes cut in it to act as handles, this made it easier to lift the bagged robot. The only down side was that we had to be careful not to rip the bag on the board.
Unread 21-09-2010, 22:21
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
That's what we did as well for transporting it, but when the robot didn't need to be anywhere, it remained off the cart and on one of our shelves (we didn't have the space, and needed the cart for our "dummy bot")
. It makes getting the robot between the trailer and the pit a lot easier.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 21-09-2010, 23:22
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
Team 525 built a pallet that fit to the bottom of the robot with four 1/4" screws. We placed the pallet on the floor with the 4 screws sticking up, set the bag in place, poked the 4 screws through the bottom of the bag, rolled down the bag, placed and bolted the robot onto the pallet, rolled up the bag and sealed it.
This leaves the pallet outside the bag for easy handling and securing the robot inside the shipping crate when we needed to ship it to the second regional which was a non-bag event.
Unread 18-11-2010, 09:27
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
Just launched in the NEMO resources.
http://www.firstnemo.org/resources.htm
Bag and Tag Tips.
Thanks to all who contributed!
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
pic: 123 ready to bag and tag J. Stofflett Extra Discussion 2 23-02-2010 11:53
Bag And Tag Jordan2389Diaz Technical Discussion 10 21-02-2010 09:14
[BB]: Bag-and-Tag procedure EricH General Forum 9 26-12-2009 20:38
Bag, Bagging, In The Bag Terms from Michigan Teams JaneYoung General Forum 16 17-02-2009 19:00
Who were the best rookies? edomus General Forum 34 01-05-2003 16:53
