Go to Post It is easier than you'd think to get yourself crossed off a draft list. I advise my teams, "Be the team you'd want to partner with." - Joe Johnson [more]
Unread 22-09-2010, 15:25
teh newbz teh newbz is offline
FRC #1771
teh newbz is an unknown quantity at this point
C++ Noob
Hello. I am familiar with Java and general programming concepts.
I would like to learn some C++ and help my team.
Where would you C++ people suggest I start?
Unread 22-09-2010, 15:34
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: C++ Noob
A good place to start would be CPlusPlus.com tutorial
Unread 22-09-2010, 15:38
FRC #1771
Re: C++ Noob
Ahh... I guess I really need to find a physical book.
I get sidetracked so easily trying to learn from websites
EDIT:
Can anyone think of a SUPER AWESOME C++ book that they really thought was great?
I know Headfirst HTML with xhtml and css was a book where I was just like "Wow... that was amazing."
That's what I'm looking for... >.>
Last edited by teh newbz : 22-09-2010 at 15:40. Reason: So I dont get shouted at for double posting
Unread 25-09-2010, 20:19
rEgonicS rEgonicS is offline
FRC #2554
rEgonicS is an unknown quantity at this point
Re: C++ Noob
"Beginning C++ Game Programming" by Michael Dawson
It's a great book for new programmers and it goes a little more in depth in classes than other C++ books. The robot's code is heavily based on classes and objects so this is a good book in particular for FIRST. The skills the book teaches you is sufficient for FIRST.
Unread 25-09-2010, 21:55
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: C++ Noob
http://search.barnesandnoble.com/boo...ean=0072225351
Its a great book, it is written as it goes through an actual college class taught by the author. Fairly easy to understand (I read it when I was ~12) Its a great book. Then after that, pick up http://search.barnesandnoble.com/C/H...b%2b+Reference its a giant book, (over 1000 pages of info) and its great referenve book. Its one of the 6 books I bought (6 books I bought in my life time -_- yea I don't read much)
edit:
e-books
http://newdata.box.sk/bx/c/
http://books.google.com/books?id=2so...page&q&f=false
Unread 28-09-2010, 21:01
Chadius012's Avatar
Chadius012 Chadius012 is offline
AKA: Sean Quinn
FRC #2508 (Armada Robotics)
Chadius012 will become famous soon enoughChadius012 will become famous soon enough
Re: C++ Noob
Starting Out with C++: From Control Structures through Objects (6th Edition) by Tony Gaddis is a great text book if you are wanting to learn C++ and its many different features. I used it for my college C++ class and learned a lot from it. Unfortunately, it is on the pricey side.
Hope this helps.
Proud Captain of FRC Team 2508 - Armada Robotics
FSA Chief of Delphi Watchers
You can always fix it with programming
Unread 30-09-2010, 02:51
Slix Slix is offline
AKA: Peter Kowalczyk
FRC #2115 (NightMares)
Slix is an unknown quantity at this point
Re: C++ Noob
I would recommend C++ Primer 4th edition or Accelerated C++. Both are highly recommended by Freenode's c++ channels.
(C++ Primer Plus is NOT the same thing as C++ Primer)
Unread 06-10-2010, 11:05
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Exclamation Re: C++ Noob
Read the manual it helped me alot: http://first.wpi.edu/Images/CMS/Firs...sers_Guide.pdf
I Am A Noob. stillyslalom Java 9 31-01-2011 15:42
Noob Question - Seeding assemblywaking General Forum 4 16-04-2010 19:08
probably a noob question EROCK NI LabVIEW 2 07-01-2009 13:24
total noob question :) Pneumaticsman Programming 15 04-01-2009 17:19
Karel++ Noob help henryBsick Programming 4 08-09-2005 16:03
