Go to Post oh, the prom! I thought you were missing a PROM (Programable Read Only Memory) ...you had me worried for a minute, I dont know if IFI has any spare PROMs. - KenWittlief [more]
Unread 23-09-2010, 10:21
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
6WD questions
I have been reading the various 6WD threads and I have some questions.
Regarding lowering the center wheel when driven directly from the motor/gearbox. How can you make it adjustable up and down or do you make the outer wheels up and down adjustable? Which method is easier to maintain and more effective over time?
Many people talk about 1/2" hex axles. Wouldn't 3/8" hex be just as effective and strong mechanically, easier to machine (if you have a smaller lathe) and cheaper to purchase a broach for (2/3rds the price)?
-T
Unread 23-09-2010, 10:31
Jared Russell's Avatar
Taking a year (mostly) off
Re: 6WD questions
It all comes down to how you are mounting your wheels, and how they are driven. There are so many different ways to manufacture a 6WD, that it's hard to enumerate through all the possibilities. How do you plan on building the frame? (Kit frame, extrusion, parallel plates, sheet metal, 2x1 or 1x1 tubing?) Just keep in mind that it is generally going to be easier (but not always) to move a wheel that is driven by belt or chain than it will be to move something that's direct-driven by a gearbox shaft.
Also keep in mind that once you have found a drop you like, you probably will never need to change it (unless your frame gets warped somehow). So unless you are designing specifically for a rapid-prototyping system, I wouldn't get hung up on being able to easily adjust wheel drop.
I defer to someone else on the effectiveness of 3/8" hex axles in FRC drivetrains, but of course, thicker axles are going to be stronger regardless of profile.
Unread 23-09-2010, 10:33
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
Re: 6WD questions
[quote=topgun;974974]
Regarding lowering the center wheel when driven directly from the motor/gearbox. How can you make it adjustable up and down or do you make the outer wheels up and down adjustable? Which method is easier to maintain and more effective over time?QUOTE]
I'm not the most mechanically inclined, but I don't understand why you would want to adjust the wheels. What I've seen is that the center wheel is dropped down (no more than half an inch, I believe) permanently. This allows the center to wheel to always have contact with the ground, and you'll always have four wheels on touching the floor. I'm fairly certain (correct me if I'm wrong) that most of the six wheel drives in FRC are never truely "six wheels touching the floor driving" type drives (unless its a six wheel swerve).
Unread 23-09-2010, 10:34
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: 6WD questions
As far as 3/8 hex axles you would run into an issue because there are no hex bearing that have a 3/8 profile that are strong, the ones AM sells state that they can not take a lot of load
Re: 6WD questions
1) Typically, you don't. Most 6WD drop drivetrains are in a fixed location. A few are flexible--the center goes up and down and is locked in. I think 1323 put out a concept for that. 330 used pneumatic center tires and could adjust the pressure for what we wanted.
2) That's a design decision you have to make. It's a little bit smaller, so the same amount of torque results in more shear stress. The more stress you have, the more likely to fail a part is. 1/2" provides a bigger safety factor than 3/8" in this application. The question is, after doing the analysis, are you comfortable with the safety factor in the 3/8"? Or, to put it another way, does the reduction in cost offset the reduction in safety factor in your mind?
Unread 23-09-2010, 12:16
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: 6WD questions
Almost all 6WD's I've seen used in FRC had fixed wheel locations. I don't really think there's any advantage to making the wheel heights adjustable in most games or on most game fields. On occasion, some teams will make the 4 outer wheels adjustable along the length of the drive train to allow for chain tensioning, but again the height from the floor does not change.
From what I've seen, 1/2" Hex is just a bit more common to find parts for. AM makes 1/2 Hex bearings and 1/2" hex wheels that have already been proven in competition.
25 has been using their 6WD since 2002/2003 and all 6 wheels touch the floor. It works fantastically for them.
-Dustin Benedict
Unread 23-09-2010, 12:50
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 6WD questions
1/2" axles are almost a must in cantilevered robots. In our past offseasons we have bent 1/2" axles in experimental testing which has led me to believe that 3/8" cantilevered axles during competition will simply make us have a bad day.
We've used 3/8" axles when both ends of the axle are supported by the frame with the wheel somewhere in the middle.
GitHub
Unread 23-09-2010, 13:30
AdamHeard's Avatar
Lead Mentor
Re: 6WD questions
We have a fixed drop, been running .125" drop on ~4" wheeels has served us well.
Universally saying X size is required isn't the greatest thing to do.
We had a prototype cantilever drive with 3/8" axles perform and last just fine, we however do 1/2" axles with 7/16" hex on our comp for geometry reasons.
Unread 23-09-2010, 13:36
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
Re: 6WD questions
Actually the six wheel swerve did have the center wheel dropped.
About 1/4 of an inch
"More power 'till it breaks or you win."
- Keith Carey
Unread 23-09-2010, 13:54
JesseK's Avatar
FRC #1885 (ILITE)
Re: 6WD questions
Rather than being universal, I meant to imply my own conclusions from my own experience. I feel that it is simply confusing to someone with a question when people respond with (in a Brian from Family Guy voice) "it depends, and here are some vague anecdotes of reason from which you cannot possible derive a logical conclusion".
Additionally, I was trying to provide context as well. Very different conclusions are drawn from the statements '1/2" cantilevered axles didn't hold up in our experiments' versus '3/8" cantilevered axles are fine for our prototypes'. Indeed, the original post didn't have anything about the context of competition or extreme environments, however it is implied by the fact that there's a good chance a third party reader who arrives at this post via search will take the information as fact during the build season (regardless of how illogical that can be, does anyone really have time to 'experiment' during the build season?).
GitHub
Unread 23-09-2010, 14:04
AdamHeard's Avatar
Lead Mentor
Re: 6WD questions
I should have further explained my point I suppose. Saying 1/2" shafts will work is just as dangerous as saying 3/8" shafts will work. The diameter of your wheel, how far it's cantilevered, how many wheels you have, what you're driving over, etc... will all effect the size you really need.
I'm just as guilty of any of doing this, I just hate the thought of a kid browsing chief and seeing, "1/2" axles! they work, we're doing it!", then spend a whole season busting axles. The other end of the spectrum is true as well, but less damaging, I'd dislike to see a team waste a half pound for no net gain.
Before we can really quote shaft sizes, we need more information about their specific shaft setup and design.
Unread 23-09-2010, 14:09
JesseK's Avatar
FRC #1885 (ILITE)
Re: 6WD questions
Ah, yes, I didn't even think about cantilever distance. Good point.
GitHub
Unread 23-09-2010, 14:18
Re: 6WD questions
Which is why I put in that it's a design decision and made reference to doing the analysis...
"It's all about the math."--Mark Leon
Failure to do the proper math correctly in this case could easily end up causing serious drivetrain problems later.
Unread 23-09-2010, 14:32
Joining the 900 Meme Team
FRC #0079
Re: 6WD questions
http://www.chiefdelphi.com/media/papers/1998 I'm just going to leave this paper here.
The thread it was originally posted in may be of some use as well. http://www.chiefdelphi.com/forums/sh...d.php?p=623114
I have to agree with Eric, do the math for your situation. I usually then have someone else check the math and then add some fudge factors in (erring on the side of caution) but YMMV.
Unread 23-09-2010, 17:24
dtengineering's Avatar
AKA: Jason Brett
Re: 6WD questions
Not all 6wd trains are cantilevered... nor do all of them use hex shafts. Keyed round stock has served us well for years.
Here's a shot of one side of our 8wd system from this year... but if you just lengthen the spacing between the wheels, you've got a 6wd.
The centre wheel in this shot is mounted directly to an extended output shaft from the KoP toughbox. (Geared down to 14:1)
Tension is adjusted by turning down the nylon rollers until they are "just right".
Jason
4WD vs 6WD SleeveofWizard Technical Discussion 3 12-01-2007 12:03
6WD? Alex Cormier FIRST Tech Challenge 14 17-04-2006 22:10
Questions about first time trying 6WD. Darkswordsmith Technical Discussion 15 18-02-2006 21:21
4wd vs 6wd? Yov Technical Discussion 22 06-01-2005 00:09
