Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 23-09-2010, 09:03
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Powering OI from battery?
We're currently finishing our T-shirt launching robot, and would like the OI to be portable. We're using the 2004 control system.
Basically, I need a way to power the OI with a robot battery. Has anyone done this? If not, does anyone know how this might be done?
Possible methods (in my mind):
1. Find documentation stating the OI can be run off a battery (not regulated 12v)
2. Use a DC-DC converter ($$$)
3. Wire up an additional robot controller, and only connect the power lines (again, I'd need documentation.)
Thank you.
Unread 23-09-2010, 09:16
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Powering OI from battery?
I don't know if you guys have VEX controllers and batteries around, but that's how we're running our t-shirt shooter. We use FRC gearboxes, victors, spikes, compressors, and solenoids with the VEX controller, and it's pretty easy to program.
Hi!
Unread 23-09-2010, 09:56
I've run OI's using an unregulated 12v battery source.
Unregulated isn't an issue since the OI regulates it down to what it needs internally.
I don't think I've ever run across documentation stating the designed input voltage range though.
We've also used a Vex transmitter rechargable as well as just a bunch of 9v batteries.
Unread 23-09-2010, 12:48
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
We purchased an inverter from Andymark for $33.00. It is small, works great and comes set up to connect with a robot battery.
http://www.andymark.biz/am-0626.html
Unread 23-09-2010, 13:52
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I second this option.
An inverter like that is an awesome thing to have, and is worth it's weight in gold. When you're at a competition when you can be away from your pits waiting for a match for an extended period of time, an inverter is a good way to keep your OI charged and up and running. I've seen a lot of teams leave the inverter and a batter on their cart and use it exclusively for powering the OI.
Oh, and it's also good for Demos and stuff too.
-Dustin Benedict
Unread 23-09-2010, 14:09
AdamHeard's Avatar
Lead Mentor
Back on 294 when I worked on the control board we would wire in an RC/Vex battery (7.2V Nimh) and a recharging circuit. They'd run for several hours without wall power at least.
Unread 23-09-2010, 14:37
Taylor's Avatar
AKA: @taylorstem
I think any way you can use a wireless controller with your t-shirt shooter would be best. If you're taking this thing to games, crowds, exhibitions, you don't want it tethered to a controller.
Of course, this is all assuming your t-shirt shooter is on a drivebase. If it's a platform shooter, then disregard the above.
Hi!
Unread 23-09-2010, 17:45
AKA Ryan Van Why
FRC #0957 (SWARM)
Thanks for the advice.
I think I/we'll order that AndyMark inverter. I too agree that it would be generally useful.
Until that gets here, however, I think we'll just run off unregulated power, for a couple reasons:
1. We have more OIs if we burn one out
2. The power brick might not be regulated well anyway (I know that many aren't)
3. We need it now.
4. It worked for AdamHeard.
Thanks for all the help.
Unread 23-09-2010, 18:38
Just to be sure, what OI are you talking about? The laptop from last year or some other controller?
Unread 23-09-2010, 19:00
AKA Ryan Van Why
FRC #0957 (SWARM)
I'm talking about the 2004 controller.
Unread 23-09-2010, 22:29
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
You are fine feeding 12 VDC into the 2004 controller. I confirmed that with IFI engineering a long time ago. I can't remember but it uses a linear regulator similiar to a 78M05 which is rated for up to 35 or so VDC.
Just make yourself a connector cable, confirm with a meter that you wired it up correctly and you can drive a long long time on a standard robot battery.
Ed Barker
Unread 23-09-2010, 22:48
AKA Ryan Van Why
FRC #0957 (SWARM)
So it doesn't care if it's not regulated? Great!
Thank you.
Unread 23-09-2010, 22:51
AKA: Dr. Brooks
no team (WRRF)
As noted earlier, the OI has an internal regulator. I would not go higher than 12 volts, however. The WRRF operated these OIs on 12 volts through the competition port for quite a few years with no problems. If you go higher, you may run into power dissipation issues on the internal regulator.
Eugene
backup battery charger from ifirobotics boygenius Electrical 1 19-02-2008 07:48
Powering the IR detector from +5V instead of 7+ V. PhilBot Sensors 7 05-02-2008 22:10
pic: Vex power from FRC battery MrForbes Extra Discussion 8 01-10-2007 11:35
Back-up battery charging circuit from IFI Don Wright Electrical 19 02-05-2006 20:41
Powering the cam without a backup battery Uberbots Programming 11 27-01-2006 10:00
