#13
Re: Powering OI from battery?
As noted earlier, the OI has an internal regulator. I would not go higher than 12 volts, however. The WRRF operated these OIs on 12 volts through the competition port for quite a few years with no problems. If you go higher, you may run into power dissipation issues on the internal regulator.
Eugene |
| backup battery charger from ifirobotics | boygenius | Electrical | 1 | 19-02-2008 07:48 |
| Powering the IR detector from +5V instead of 7+ V. | PhilBot | Sensors | 7 | 05-02-2008 22:10 |
| pic: Vex power from FRC battery | MrForbes | Extra Discussion | 8 | 01-10-2007 11:35 |
| Back-up battery charging circuit from IFI | Don Wright | Electrical | 19 | 02-05-2006 20:41 |
| Powering the cam without a backup battery | Uberbots | Programming | 11 | 27-01-2006 10:00 |
