Re: [FTC]: baton resistance
Personally I think this will be depending on who built the field and a few other factors. Ours are fairly hard to remove, some might be easy to remove. Some friendly advice would be to design for the "worst". Note: Its not really that bad. worst is considered the hard to remove ones.
There is "a lot" of clearance inside the dispenser. The side rails are 1" and the OD of the PVC is about .8". Also remember the weight of the other batons pushing down inside the dispenser. The fuller the dispenser, the more force you'll need to overcome the weight and gravity.
| [FTC]: FTC baton dispensers | jaster67 | FIRST Tech Challenge | 6 | 21-02-2011 17:09 |
| [FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) | Mr. Lim | FIRST Tech Challenge | 2 | 03-03-2008 11:54 |
| Engineering mentor looking for a team in or around Baton Rouge | Dan-o | General Forum | 4 | 21-11-2007 10:34 |
| 662's Practice Kickoff - Baton Blitz | Cyberguy34000 | General Forum | 4 | 07-12-2006 12:44 |
| Design Challenge: Baton | Mike | Technical Discussion | 27 | 12-12-2005 16:41 |
