Go to Post Smart defense doesn't even require your robot to push another. - Cory [more]
Unread 24-09-2010, 20:49
nealpatel nealpatel is offline
FRC #1777
nealpatel is an unknown quantity at this point
Access Classes from different file
Does anyone know how to access java classes from a different file? We have always used only one file for all code but now it's so big so I was wondering if there is any way (I'm sure there is some way but idk) to do that.
Like for "User Messages", we made a class "writeUM".
public void writeUM(int line, String Message) {
if(line == 1) {
uM.println(DriverStationLCD.Line.kMain6, 1, Message);
uM.updateLCD();
else if(line == 2) {
uM.println(DriverStationLCD.Line.kUser2, 1, Message);
uM.updateLCD();
else if(line == 3) {
uM.println(DriverStationLCD.Line.kUser3, 1, Message);
uM.updateLCD();
else if(line == 4) {
uM.println(DriverStationLCD.Line.kUser4, 1, Message);
uM.updateLCD();
else if(line == 5) {
uM.println(DriverStationLCD.Line.kUser5, 1, Message);
uM.updateLCD();
else if(line == 6) {
uM.println(DriverStationLCD.Line.kUser6, 1, Message);
uM.updateLCD();
So this is at the end of our program. I was wondering if I can put this in a different file and call that file instead.
Thanks.
Neal Patel
Team 1777
Shawnee Mission West
Viking Robotics
e-mail: neal.patel11@yahoo.com
Unread 25-09-2010, 15:17
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: Access Classes from different file
You can do that quite easily in fact.
package WriteMessage.*;
public class WriteMessage{
//lots of code
In your main robot code file:
import edu.wpi.first.wpilibj.*;
import WriteMessage.*;
public class RobotFile{
///when you want to access you method
WriteMessage.writeUM(5,"Hello World");
NetBeans does a really good job of helping you out on this type of stuff.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 27-09-2010, 22:19
lusterlink's Avatar
lusterlink lusterlink is offline
FRC #1160 (FireBird Robotics)
lusterlink is an unknown quantity at this point
Neal-
Quick question. Do you mean accessing the class or method outside the file? Because it seems your asking if you can access the method outside the file.
If you want to access the class, simply add the import to the top of the file.
If you want to access the method, you might have to look towards static methods.
P.S. I might be completely wrong, if so correct me.
buildmaster, I attempted to run your code... Its a no go, I think because method must be static.
Unread 27-09-2010, 22:26
FRC #1777
I actually figured out what I wanted to do. It's basically what you wrote but I made it easier and different.
Thanks though.
Neal Patel
Team 1777
Viking Robotics
Unread 27-09-2010, 22:30
FRC #1777
Originally Posted by lusterlink View Post
Neal-
IDK what you mean and what I meant by class or method.
Anyways, I figured out what I wanted.
And if you failed to run my code, you did something completely wrong as this code is working since forever, I just want the whole "writeUM" thing in a different file.
I'm good now. Thanks everyone who tried to help.
Neal Patel
Team 1777
Viking Robotics
Different approach from a rookie player feliks_rosenber Rules/Strategy 12 15-01-2007 15:59
What information can we access from the camera? Total Meltdown Programming 37 01-02-2006 11:24
What information can we access from the camera? Total Meltdown Programming 13 08-01-2006 13:50
Combining multiple objects in different files into the same scene and file? DinkyDogg 3D Animation and Competition 8 19-02-2005 19:14
Good book to learn MS Access from? Elgin Clock Math and Science 2 05-10-2004 20:20
