Go to Post "And that right there is the Sharpie line between right and wrong. Guess which side you cut on?" - Cypher [more]
Unread 26-09-2010, 01:11
VashonRobotics's Avatar
VashonRobotics VashonRobotics is offline
AKA: Bruce
FTC #3861 (Vashon Pirates)
VashonRobotics is an unknown quantity at this point
[FTC]: Answers for an inexperienced team
We are a 2nd year rookie team and have a question that someone might know from experience.
If in Autonomous mode your bot tips over and becomes immobile (for example this year going over the mountain or fall off a cliff) does it stay there through to the end of the match?
Thanks
Unread 26-09-2010, 01:38
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: Answers for an inexperienced team
Unless it manages to flip its self back over, or the alliance partner manages to do so, sadly yes I believe your robot would be stuck that way the remainder of the match. Unless I am missing something in the rules, which is a possibility.
Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 26-09-2010, 09:00
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
That is pretty much the case in any robotics competition, FRC, FTC, VEX, BEST, etc. once your are down, you are down. It's one of the reasons that we try not to build "tippy" robots. We teach roboteers :
  • about having low centers of mass
  • keeping the center of mass over the robot base
  • that the center of mass changes as the robot moves up and down ramps
  • that the center of mass changes as the robot reaches and lifts objects
and if needed, building righting mechanisms to stand the robot back up. While self righting robots receive huge cheers at events, it does take valuable time that you could put to better use scoring.
All part of the "Science" in action in building a robot!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 27-09-2010, 10:16
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I predict that flipping will happen regardless of 'tippiness'. Two line-following robots on opposing alliances will meet on the mountain in autonomous. One will probably flip. The other will probably drive on top of the flipped one. More [tragic] hilarity would ensue if both flipped backwards.
Other than that, we teach that center of innertia is what we want to keep low; CoI and CoM are the same exact thing, yet CoI implies an object is in motion and can be 'pulled' parallel to the ground. Teaching this gets students to consider dynamics of design as the drive train rapidly accelerates.
GitHub
Unread 11-10-2010, 13:15
Sheila Sheila is offline
FTC #4211
Sheila is an unknown quantity at this point
We are a rookie team and had a questions about linear gears. Are there any linear gears available for FTC teams ? We did not find anything in the Tetrix parts and not sure the LEGO linear gears would be durable enough.
Any chance we could make our own linear gear from the flat aluminum or plastic sheeting listed as acceptable materials - is something like this allowed ??
Unread 11-10-2010, 14:54
You can always double up on the gears so they run side by side. In VEX parts we have rack/pinion gears that we've run side by side to lift 20 lbs of robot. An important design point is to try to have more than one tooth of the gear take the load. So if you can use a larger spur gear to drive your rack gear that would help.
Unread 11-10-2010, 16:57
Chris is me's Avatar
AKA: Pinecone
As for tipping, knowing the FTC kit motors I would see if you could work on a mechanism that has the power to right your robot in the case of a tip. Considering you probably have an appendage to grab batons, maybe this same appendage will be able to flip yourself back up?
Unread 02-11-2010, 12:47
pend pend is offline
Steve P.
AKA: Steve Pendergrast
FTC #0247 (Fatal Error)
pend is an unknown quantity at this point
Last season we used an ultrasonic sensor to detect oncoming defensive ram attempts in autonomous against our robot, and the robot would divert to an alternative firing position if it saw the oncoming intruder. The same strategy might work to avoid a head-on collision on the mountain. We're experimenting with it. Of course, that allows the opponent to score the 10 points for crossing if you're the one who backs off. I guess it's possible to detect an oncoming mountain-climber collision and then decide to divert to crossing over one of the bridges instead. 40 seconds is a long time.
[FTC]: Looking for a registered FTC Team to do us a favor BlackBoxFTC FIRST Tech Challenge 7 20-09-2010 13:46
[FTC]: Looking for a working 2008 FTC program mjgard FIRST Tech Challenge 4 06-11-2009 11:52
[FTC]: Email Blast: FIELD MANAGEMENT FORMAT FOR FTC WORLD CHAMPIONSHIP PhilBot FIRST Tech Challenge 18 29-03-2009 21:04
Team Numbers for FTC Programs Rick TYler FIRST Tech Challenge 2 08-04-2008 17:33
Answers for Dead Reckoning... FOR BEGINNERS actorindp Programming 6 20-02-2004 23:56
