Go to Post The world isn't made out of Nerf, you will get scrapes and bruses, but you will get back up and continue on. If you watch out you can avoid the sharp edges. - Joe Matt [more]
Unread 26-09-2010, 11:06
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: [FTC]: Source needed for FTC playing field mats.
You can find accurate/accepted substitutes for the Softiles brand by going to a Lowes, Home Depot, or Toys-R-Us.
Unread 26-09-2010, 11:23
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
We get our tiles at BJ's. Note that different mfgs tiles are incompatible. Some have an even set of fingers, some have one finger that is at an angle (offset) in the middle. Smooth side goes up, the marking tape sticks better to that side.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 26-09-2010, 13:42
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
FTC Teams receive an education discount at Soft Tiles. The order needs to be placed over the telephone to receive the discount. https://www.softtiles.com/content/view/52/1/
FTC uses the Gray 2 x 2 mats that are 5/8" thick. https://www.softtiles.com/content/view/28/39/
Unread 27-09-2010, 11:51
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
Not sure how good the educational discount is from SoftTiles ($209 without), but I've posted these near identical ones in previous threads on this topic as they are only 1/8" thinner & cost just $90!
http://www.amazon.com/We-Sell-Mats-A...MQ/ref=sr_1_51
Note that since these are not the exact same as those at the competition, there is the possibility of a slight color difference (important if you're calibrating color sensors for line tracking). My own teams haven't had any issues with these mats though as they really are nearly identical.
Always good to have options.
Unread 27-09-2010, 13:02
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Competition mats are 5/8" so these are a full 1/4" less in thinkness but field tolerances for element construction are more than that. If you use these for practice just know that you will be off in vertical dimensions to the elements mounted on the field perimeter while no difference for those elements sitting on the field surface
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 27-09-2010, 13:56
Good catch.. I accidentally noted the difference as 1/8", but it is actually 1/4" as you point out.
We already have a custom paremeter made out of plywood and customize all wall mounted game elements as needed to work with our setup while being as close to the actual specs as possible, but always well within the 1" tolerance.
[FTC]: Cleaning Floor Mats jamie_1930 FIRST Tech Challenge 5 27-09-2010 17:01
[FTC]: Building Low Cost Playing Field Christine3491 FIRST Tech Challenge 1 26-09-2009 08:57
[FTC]: Email Blast: FIELD MANAGEMENT FORMAT FOR FTC WORLD CHAMPIONSHIP PhilBot FIRST Tech Challenge 18 29-03-2009 21:04
[FTC]: TV ad for San Antonio, Texas FTC tournament Andrew Schuetze FIRST Tech Challenge 2 25-08-2008 08:00
[FTC]: 2008 FTC World Championship volunteers needed KathieK FIRST Tech Challenge 0 20-01-2008 21:54
