Go to Post My friend Noah said he talked to someone that knew me from Chiefdelphi. That's just creepy. - Adam Y. [more]
  #61   Spotlight this post!
Unread 29-09-2010, 06:27
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Are they really robots?
So according to Asimov, cars and airplanes are robots.
I don't think it sums it up quite as neatly as you thought.
(since 2004)
  #62   Spotlight this post!
Unread 29-09-2010, 08:36
Parts of some of them are, certainly. Cruise control, the fuel metering system on just about any modern car, paddle-shifting transmissions, the entire hybrid powertrain on a Prius, etc. An airplane under the control of an autopilot is an autonomous robot using just about any definition that doesn't require robots to have hands.
  #63   Spotlight this post!
Unread 29-09-2010, 08:52
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Autonomy seems to come up often in this discussion. This brings me to three questions:
Is there a distinction, as far as autonomy and the classification thereof is concerned, between closed-loop and open-loop programming?
Are the controls (joysticks) considered to be sensors, or simply inputs?
Is there a distinction between sensors and inputs?
Hi!
  #64   Spotlight this post!
Unread 29-09-2010, 10:01
I don't think such a distinction would be important when deciding whether or not a machine counts as a robot. There are many examples of open-loop robotic "pick and place" machines in assembly lines, for example. But there's definitely room for debate on the topic, and one could make a valid comparison between totally open-loop systems and clockwork wind-up mechanisms.
I would consider that a matter of semantics rather than of essence. The system analysis could be done with either choice of label.
I probably wouldn't use the word "sensor" to describe an input device such as a keypad. Sensors typically measure or detect a quality of the environment, while inputs can be pure information without a definite physical analog.
  #65   Spotlight this post!
Unread 29-09-2010, 17:03
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
I'd classify inputs as being more general and sensors as a specific type of input, though I'll decline to define it here. One might also distinguish inputs which require human interaction as "manual inputs".
But just to add to the confusion, within each manual input probably lies some kind of sensor and/or transducer - within keypads there are gizmos which close circuits when enough force is exerted (switches) and within joysticks there are thingamabobs which sense position and output voltage (potentiometers).
- Steve
  #66   Spotlight this post!
Unread 29-09-2010, 23:48
Bob Steele's Avatar
AKA: Bob Steele
When an operator is operating a robot is the operator using the robot or is the robot using the operator?
Are we not just part of the robotic system... our eyes, brains and hands doing the same functions as other sensors that the robotic system uses to perform a particular function..
BE the robot...!! Resistance is futile....
Is the task what makes the robot? In fulfilling the task we are just helping the robot make the decisions it must to function...
Our input comes from our very own sensors.... which are programmed in our brain.. we use those sensors to send stimuli to the robot which allows it to take those signals and translate them into movement... and task fulfillment...
Robot philosophy
  #67   Spotlight this post!
Unread 30-09-2010, 00:44
What happens if a robot controls its own joystick. Is it really a robot?
  #68   Spotlight this post!
Unread 30-09-2010, 01:41
AdamHeard's Avatar
Lead Mentor
I've always wanted to make a little demo robot which is a simple arm holding a joystick. When the joystick is pushed left, the arm is powered right, and vice versa. Completely off topic, but it would certainly be cool to see.
  #69   Spotlight this post!
Unread 30-09-2010, 08:11
We had a robot in '04 that, while holding it's own controls, rose up out of a floor on a lift, turned and found the drive team, then drove to the humans to deliver its' controls.
This was for an SBPLI fundraiser dinner while the diners watched with Also Sprach Zarathustra playing.
... then it nearly ran over a small table someone had placed in the way holding the boombox playing the 2001 Space Odyssey theme...
If it's klutsy is it still a robot?
  #70   Spotlight this post!
Unread 30-09-2010, 09:00
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
My first reaction is "No, but why does it matter so much?"
I can say that regardless of whether or not it's a robot is utterly irrelevant to FIRST participants. The definition of a word doesn't subtract from the invaluable experience the community derives from FIRST.
Team 501 Academic Advisor, Systems Build Mentor
  #71   Spotlight this post!
Unread 30-09-2010, 10:24
It's still a robot, but there are certain groups which frown upon that sort of behavior.
  #72   Spotlight this post!
Unread 30-09-2010, 14:37
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Originally Posted by Vikesrock View Post
He suggested that by emphasizing the mechanical and electrical aspects of our creations to the detriment of software that FIRST and associated vendors are being harmful and preying on the ignorance of the average high school student to what a "robot really is".
You can't build a robot without a frame. You can't build a robot without electronics. You can in fact build a robot without software.
  #73   Spotlight this post!
Unread 30-09-2010, 14:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Already mentioned in this thread, but couldn't a robot be 100% mechanical?
  #74   Spotlight this post!
Unread 30-09-2010, 17:09
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
I think Da Vinci would disagree with the electronics being needed policy we're following
Also how is it could they not be robots if your reasoning is that they are remotely operated by humans during teleoperated period if they can also function autonomously during autonomous period
Airplanes can be completely mechanically operated machines, but can also pilot themselves if need be. In addition the dictionary.com definition of sensor is
anything, such as a photoelectric cell, that receives a signal or stimulus and responds to it
so wouldn't a joystick be a sensor?
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
  #75   Spotlight this post!
Unread 05-10-2010, 10:01
Adam Y.'s Avatar
Adam Y.
no team (?????)
I forgot to mention this but yes airplanes should be classified as robots at this point. They can land by themselves. They can fly by themselves. The only thing I'm not entirely sure about is them taking off on their own.
Are these wheels available, anf if not are they ever gonna be? Elgin Clock FIRST Tech Challenge 3 12-11-2005 22:27
Robots really are nuclear powered suneel112 Electrical 14 25-04-2004 12:25
Are your engineers really what they seem? MissInformation Chit-Chat 11 18-12-2002 12:54
M12 and Q12 -- do they really mean this? archiver 2001 1 23-06-2002 22:45
