Go to Post Listen, my team lost in the finals to that alliance, and I've never suffered a more entertaining arse-kicking. Case closed. - Petey [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Programming
Unread 30-09-2010, 23:21
Fireball9199 Fireball9199 is offline
Rocket Surgeon
AKA: John Begovich
FRC #0068 (Truck Town Thunder)
Team Role: Electrical
Fireball9199 is a name known to allFireball9199 is a name known to allFireball9199 is a name known to allFireball9199 is a name known to allFireball9199 is a name known to allFireball9199 is a name known to all
[OCCRA]: Assembly on the cortex
Is it possible to program the cortex controller completely in assembly?
if so, how would I go about doing this?
Edit: Grammar
Unread 01-10-2010, 07:35
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: [OCCRA]: Assembly on the cortex
Assuming you knew the microprocessor it has (the VEX site says it has an STMicroelectronics ARM Cortex, with some specs on RAM/FLASH, so that should narrow it down), and how the master communicates (I know it uses SPI), you should be able to do that. You could also use GCC/G++ for ARM, and cross-compile to that if you don't like EasyC.
Kettering Motorsports
Unread 03-10-2010, 19:52
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Warning! OCCRA officials and staff will not support any software other than the supplied EasyC V4 ( for Cortex and EasyC v2 for vex).
If you choose another software it may not be compatible with our field control software and we will not take responsibility if you cannot communicate and therefore run in a match.
Mike Martus
Unread 04-10-2010, 21:35
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Smile Re: [OCCRA]: Assembly Language programming on the cortex
Unless you have an absolutely great reason to use assembly code while competing with an OCCRA robot, please do not attempt to use assembly language coding. Please contact me if you are seriously attempting to go down this path - I will discourage you and encourage you to use EasyC V4 Cortex for the OCCRA competition. We don't have the software tools in house to debug and support this effort by students.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
[OCCRA]: cortex power supply off/on bernieseaholm OCCRA Q&A 1 23-09-2010 08:32
[OCCRA]: what time is the occra banquet? MatthewArthur OCCRA 3 01-12-2005 17:28
[OCCRA]: After the first OCCRA competition ah27 OCCRA 7 27-10-2004 22:16
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
