Go to Post I pumped my fist to cheer - but since I was a ref at the time it looked like I signaled a red foul... - Tom Ore [more]
Unread 01-10-2010, 13:22
Re: Dust Collection Systems
Originally Posted by kramarczyk View Post
Dust collection can get serious if you are going to spend a lot of time in the shop. Dust is not just a nuisance, it can also be a health hazard.
I've seen teams use shop air to clean drill presses, milling machines, band saws, and bench grinders. This always concerned me as a lung hazard, but I don't have any authoritative info. Does any have any links they could post ?
Unread 01-10-2010, 13:47
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
dust collection really isn't that big of an issue if you clean up at the end of each day. it only is really necessary for planers, unless you are using a large wood shop. the only tool other than planers that really need collectors are sanders and maybe band saws.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 01-10-2010, 15:57
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
I was speaking more to the wood dust as a health hazard as I don't typically speak of metal by products as dust. According OSHA... http://www.osha.gov/SLTC/wooddust/index.html
Wood dust becomes a potential health problem when wood particles from processes such as sanding and cutting become airborne. Breathing these particles may cause allergic respiratory symptoms, mucosal and non-allergic respiratory symptoms, and cancer.
Additionally, certain engineered wood products contain additional hazards. An example is MDF and plywood both contain formaldehyde. http://www.flakeboard.com/msds/Flake...r_MDF_MSDS.pdf
http://www.timberproducts.com/.docs/..._MSDS_2005.pdf
As far as using shop air to clean metal cutting tools, I have always been told that this created a airborne eye hazard and that a brush and pan were a better practice. In my experience, metal chips don't hang in the air as readily as wood does. I doubt putting cutting fluid airborne as a mist does ones lungs any favors though. OSHA is a little more vague here... http://www.osha.gov/SLTC/metalworkingfluids/index.html
Your milage will of course vary based upon the amount of time and intensity of exposure. Personally I don't spend a lot of time worried about it, but if I am going to cut MDF in my garage with the door closed (winter) then I do put on a resperator.
Mark
Brick walls are for other people. - Randy Pausch
Wanted: Space-Age Dust Removal JohnBoucher NASA Discussion 15 01-05-2008 09:02
Mars dust storms suck life out of rovers JohnBoucher NASA Discussion 27 04-09-2007 19:58
Dust iamnafets 3D Animation and Competition 1 19-02-2004 18:27
Team 398 lost in the dust? kellyG Robot Showcase 1 29-03-2003 22:44
pic: Another one bites the dust! CD47-Bot Extra Discussion 1 14-03-2003 08:40
