Go to Post 2011. Tried swerve. Didn't move for 1.5 regionals. - cadandcookies [more]
Unread 26-09-2010, 01:55
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
[FTC]: New Tetrix Parts
Thought I would share this if anyone wasn;t aware.
Today the new parts in the Tetrix kit were released.
New parts consist of:
Continuous Rotation Servo
Tread Rubber Inserts
Tread Conveyor
Tread Idler Wheels
Tread Sprocket
Tread Links
Tread Kits
4" Omni-Wheels
Tread Accessory Pack (which I am having trouble figuring out what is in this "pack")
The link is below
http://parts.ftcrobots.com/Default.aspx?bhcp=1
Hope this helps
Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 26-09-2010, 10:14
Tony Allen Tony Allen is offline
TETRIX Product Manager
Tony Allen will become famous soon enough
Re: [FTC]: New Tetrix Parts
The Tread Accessory pack will consist of paddel's for turning your tread system into a conveyor and rubber inserts for the treads. Also a new thermal protected DC Motor power cable will be an added as a new part.
Unread 30-09-2010, 09:32
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
I noticed that the continuous rotation servo does not have position feedback. Am I correct in understanding this means that I can only tell the servo to go forward or backward and not to go to a specific point? Or am I misunderstanding what this means.
"Don't worry, programming can fix it"
Unread 30-09-2010, 10:12
Aren Siekmeier's Avatar
on walkabout
Seems that it's not much of a servo without position feedback.... I don't know...
Unread 30-09-2010, 10:19
Your understanding matches mine.
We did this to a couple position servos when I was in highschool. Basically, you break the internal feedback loop and remove the hard stops and it turns into something that approximates a normal motor.
I agree that it likely doesn't deserve the "servo" moniker at this point: It looks like a servo, talks like a servo, but doesn't quack like one. Not sure what I would call it. "Motor with integrated control electronics" doesn't sound as sexy as "continuous rotation servo"
Unread 30-09-2010, 19:19
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
I tend to call them miniature speed controllable geared motors.
(At least the parallax ones are speed controllable, I have no idea about these ones)
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 01-10-2010, 08:48
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
The speed control on a "hacked" servo is crude at best. Most really ARE just a gear reduced motor in an easilly mountable container.
It depends on whether they just removed the mechanical stops/feedback, or changed the drive circuit
What IS certain is that there is no position feedback.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 01-10-2010, 14:20
biojae's Avatar
Originally Posted by PhilBot View Post
The speed control on a "hacked" servo is crude at best. Most really ARE just a gear reduced motor in an easily mountable container.
Phil.
I have only dealt with the parallax continuous rotation servos, those are speed controllable.
It would be nice if these ones could be speed controlled.
Unread 01-10-2010, 14:35
Chris is me's Avatar
AKA: Pinecone
This is not a facetious question; I know of an FTC team that's actually looking for the answer to this.
Are the new tank treads close enough to the Vex tank treads in size, shape, etc. that they can use the Vex tank tread links in their place? I think the rules permit "duplicates" like that. They're looking to save a little bit of cash for a particular feature and want to only buy the sprockets, and they look similar enough that I figure it's worth asking, but since I / they don't have any new tread material in hand they can't really compare the two.
Unread 01-10-2010, 15:13
AKA: Andrew Remmers
Sadly the rule with using VEX parts in FTC was removed last year. Using VEX tread would be illegal even if they had the same size link.
"g. Vex parts of any type are not allowed."
Sorry for the bad news on that aspect.
But what they could do is look for a sponsor or something to donate some money. We got $1800 donated from things that were in our build space for FRC.
I agree that FTC parts are a little on the expensive side, which is why our team tries to avoid modifying them at all cost.
Andrew
Unread 01-10-2010, 15:20
AKA: Pinecone
That's a bit disappointing. I thought I read a rule about "identical replacement parts" or something, but after a second read through I can't find it. There goes $70...
Unread 01-10-2010, 15:23
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
...What IS certain is that there is no position feedback.
OK - I'll ask... Can anyone tell me why they would call this gizmo a "Servo" instead of calling it a motor? Maybe to pander to some RC enthusiasts that call any motor (except the main drive motor for a vehicle) a Servo? I'm confused.
Originally Posted by Joyride_67_1902 View Post
Sadly the rule with using VEX parts in FTC was removed last year. Using VEX tread would be illegal even if they had the same size link....
Do the currrent rules allow replacement parts of any sort?
Blake
Unread 01-10-2010, 15:29
biojae's Avatar
Originally Posted by TETRIX® Continuous Rotation Servo
Featuring fully proportional forward and reverse speed control
http://parts.ftcrobots.com/store/det...01&c=0&t=0&l=0
It appears that the FTC continuous rotation "Servos" are speed controllable.
Unread 01-10-2010, 17:04
AKA: Andrew Remmers
If we could use identical parts I'd think we would just buy gear stock instead of gears from Tetrix. We however can use identical hardware from anywhere in any length which will come in handy im sure.
Unread 01-10-2010, 17:08
AKA: Andrew Remmers
I'm guess I'm having a hard time interpreting what you mean by replacement.
Do you mean like a spare part in tetrix kit, or something that does the same thing even looks the same from out of kit?
[FTC]: Anyone new to FTC or TETRIX, READ THIS NOW! PhilBot FIRST Tech Challenge 21 04-12-2009 17:34
[FTC]: VRC (VEX) AND FTC (Tetrix) jbbjjbt FIRST Tech Challenge 1 21-09-2009 14:59
[FTC]: CAD Models of Tetrix parts? Madison FIRST Tech Challenge 2 23-11-2008 08:49
[FTC]: FTC Tetrix Extra Parts Team 288 FIRST Tech Challenge 2 22-10-2008 18:30
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
