Go to Post It is usually the simple things that get you. - Andy Brockway [more]
Unread 04-10-2010, 13:26
Brandon Holley's Avatar
Re: Belt Drives
Originally Posted by Chris is me View Post
Fun question: I've heard that belt drives never stretch. Does that mean if you CAD appropriately and use exactly the right belts, you don't need tensioners other than to more fully engage pulleys? I've seen photos of 1717 robots with belts used without tensioners before... Are they a requirement, or just nice to have?
Theoretically, yes, you should be able to design the distance between centers to a correct interval and end up with a belt without tensioners. However, the belt drives I've done have all ended up with tensioners. This was just to bulletproof the setup should anything change throughout the course of the season. The nice thing about these tensioners was they did not need to be variable. It was literally a piece of delrin turned to the correct diameter and placed over a standoff that was inline with the belt path. We had little issues with the belts with the tensioners in place. Post-season we ran without tensioners to test the setup and did end up failing a belt (sheered teeth) after 3 or 4 post season events. Luckily we had replacements at the ready and did a quick swap and reinstalled the tensioners.
I would say if your considering a belt setup, order some samples and just play with them yourselves. Use the fall to develop some kind of a prototype using belts. It doesn't need to be an entire drive system. Maybe even try to do some lifetime testing and see if they do stretch in your applicaation.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 04-10-2010, 13:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Belt Drives
When I was in HS I designed two transmissions for a CNC plasma cutter using belts, without tensioning mechanisms. I recently visited my old HS and found that both belts are still tight 5 years later. Very encouraging.
While my team has never used belts for the drive system, we've used them on roller systems in 2001 and 2003 and in 2002 for swerve drive steering. None of these had tensioner systems and they worked well.
Friction drives newbee General Forum 5 11-01-2009 20:32
Drives in general Gamerboyb1 Technical Discussion 26 12-11-2007 19:28
holonomic drives Max Lobovsky Technical Discussion 5 10-03-2004 21:31
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
