Go to Post The flux capacitor should have been allowed under the flowchart as long as it met the single component maximum cost. I did check with Digikey and they no longer carry the line. - Al Skierkiewicz [more]
Unread 01-10-2010, 19:37
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
Old FIRST radio pin-out?
Anyone know the pin-out for the RS422 radio link used in past years? I found this thru Google, but it was stated that's there's no real standard, so I don't know if theses radios are the same:
Pin Function
1 No Connect
2 –Rx (RS-232), –Tx (RS-422)
3 –Tx (RS-232), –Rx (RS-422)
4 +Rx (RS-422)
5 Ground
6 +Tx (RS-422)
7 No Connect
8 No Connect
9 Ground
Unread 01-10-2010, 20:45
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Old FIRST radio pin-out?
I have the pin outs, tech manual, and an email with the packet info. PM me with your email address.
Unread 01-10-2010, 21:14
FRC #1277
Thanks!!!:
Unread 01-10-2010, 21:25
Email sent. You might want to delete your email address from above before your mailbox starts filling up with spam.
Unread 02-10-2010, 15:53
FRC #1277
Thanks again. Really appreciate it.
9 pin cable from radio to RC sparrowkc Rules/Strategy 1 23-01-2008 21:03
IFI LED pin out Andy Brockway Kit & Additional Hardware 1 13-04-2006 21:30
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
