Go to Post but look at the bright side, you will now be able to size 1/4-20 nuts with your forearm and i doubt there are many people who can say that :p - Greg Needel [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 01-10-2010, 11:27
bakketti bakketti is offline
FRC #0443 (Freelance Robotics)
bakketti is an unknown quantity at this point
Dashboard Example Project
Our team is experimenting with Java in the off-season (thinking about moving from Labview) and I'd like to get familiar with the Dashboard capabilities. The Sun Spot FRC Info tab in NetBeans has a dead link to a file named DashboardExampleProject.zip. The file is no where to be found on my computer (or through google searches). Does someone have this file available on their computer or know where it can be found online? If so it would be greatly appreciated if you could share.
Unread 02-10-2010, 00:24
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Kevin Wang is an unknown quantity at this point
Re: Dashboard Example Project
In NetBeans, go to File > New Project. Under Categories, select Samples > FRC Java, and under Projects select DashboardExampleProject.zip.
Here's a document I found by team 330 which you might find interesting:
http://www.scribd.com/doc/27095630/LabVIEW-Dashboard
Unread 10-10-2010, 20:54
Nevermind! found it.
Unread 09-02-2011, 00:34
MathFreak's Avatar
MathFreak MathFreak is offline
Team Leader/Electrical
AKA: Hikari Iwasaki
FRC #5701 (Indigo Ninjas)
Team Role: Electrical
MathFreak is on a distinguished road
I can't find FRC Java in the Samples... it is saying:
Java
Java FX
etc...
is it because I downloaded the wrong thing?
Hikari Iwasaki
2nd Grade student at Senior High school at Otsuka,University of Tsukuba
2014 Team5701 Team leader
2011 Team 296 Youngest team member
Team 5701 Indigo Ninjas
Website
Facebook
Twitter
Blog (in Japanese)
Unread 09-02-2011, 08:14
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Are you sure you installed the FRC plugins properly? You should see at least some FRC sample code projects when you try to create a new project.
Unread 09-02-2011, 13:00
MathFreak's Avatar
AKA: Hikari Iwasaki
Nevermind I got what I didn't do I forgot to install the FRC plugins... thanks!
Hikari Iwasaki
Website
Facebook
Twitter
Blog (in Japanese)
Unread 16-12-2012, 21:25
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Hello. I cannot seem to understand what is going on and what I am supposed to do. I have several ints that I send along to labview through the Dashboard class. unfortunately, when I try to get those numbers in labview, I get an error telling me that there is no second digital module, then that there is no second analog module. As the code runs these come up every 5th of a second. What am I doing wrong?
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
example project Autonomous mode Watchdog problem qpang NI LabVIEW 0 08-02-2010 16:17
Windriver - Cannot Create New Example Project Aaron S C/C++ 6 19-01-2010 21:25
Default Labview Dashboard and Windriver Example Help sircedric4 Programming 7 25-02-2009 01:58
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors DanDon LabView and Data Acquisition 3 29-01-2009 22:13
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors Russ Beavis National Instruments LabVIEW and Data Acquisition 9 21-01-2007 17:19
