Re: pic: Reverse Drive
Side note: Another way to fix this that's always worked for me is wiring one of the motors backwards. (wire the Victor's output backwards, not the input)
I'd learn to calibrate the victors, it's very easy to do, and should be done to all victors each year.
That could give you problems with a strict robot inspector. Wiring must comply with the color coding rules. Yes, you can tape over the entire motor lead, but this only simplifies your code, it doesn't eliminate bias. As long as the motors are oriented 180 degrees apart one has to travel in the opposite direction to the other to move in the same relative direction.
Reminds me of this: http://www.chiefdelphi.com/media/photos/17269
The drill motors we used until 2005 had horrendous bias (around 10% if I recall correctly), so some teams came up with ways to correct for it mechanically. |
| reverse hurdle. | Stillen | General Forum | 5 | 06-02-2008 19:59 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| Reverse Gear | FizMan | Technical Discussion | 12 | 26-04-2004 01:29 |
| Reverse Robotics !!!!!!!!!! | dan 322 | General Forum | 42 | 25-04-2004 00:44 |
| Chiaphua in reverse?? | Christina | Motors | 2 | 09-01-2002 08:40 |
