Re: Bandsaw
We use a cutoff saw, handheld, for cutting steel and threaded rod. We use an old 8" miter saw for cutting aluminum angle, 8020, pvc pipe, etc., and a 14" delta bandsaw for sheet aluminum, wood, and lexan. |
Re: Bandsaw
Re: Bandsaw
The cut was rough and the blades went dull very quickly. One of our mentors looked at the possibility of changing gear ratios, since it is a belt drive, but it would take a lot of modification to cut the speed down to a 1/10 of what it is now. Also some of the mechanisms to keep the blade inline were never great
Re: Bandsaw
You could buy or make a stand for a portaband type saw if it is large enough for you. Or just make a better horizontal table for the Harbor Freight type.
http://www.swagoffroad.com/Porta_band_Product.html http://www.swagoffroad.com/Porta_ban...t_Product.html |
| Bandsaw Troubles | John Gutmann | Technical Discussion | 6 | 13-07-2006 02:05 |
