Go to Post If there isn't unity in your team, the outcome will never be good. - Arefin Bari [more]
Unread 05-10-2010, 18:31
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Whats the Best way to do Bumpers?
During our Monday meeting my team got to talking about last years bumpers. We concluded that although our bumpers worked quite well, there were better ways to do them. I was charged with finding a past thread on the subject if one existed, and starting a new thread in the event that it didn't. I didn't see one so here goes...
I'm basically wondering:
1: How did your team do your bumper mounting or otherwise? (I know there is that very cool flip method.)
2: What was the best bumper mounting you saw during the season, I'm talking about either functionality or looks. (on the killer bees we're all about looking good.)
To get the discussion rolling: my team made pretty standard bumpers which attached to the frame via 1" aluminum L bracket and some... I'll call them easy bolts for lack of a better term as they could be screwed and unscrewed quickly be hand. However, we had 8 different bumper parts which were kind of cumbersome. (4 red 4 blue)
Thanks in advance, this will be a great help.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 05-10-2010, 19:15
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Whats the Best way to do Bumpers?
We used 2 L-brackets per attachment point (2 or 3 points on each bumper). There were holes drilled through the outward part of the L-brackets as well as through our robot's frame. To attach the bumpers, they were placed on the frame and then pins (basically these) were placed through the holes so that the pin went in the top bracket, through the frame, and out the bottom bracket.
For color of bumpers, we attached snap buttons to the bumper and to our blue fabric, which allowed us to go from blue to red almost instantly with one person per bumper (red to blue was obviously harder).
This system allowed us to switch from red to blue in < 3 minutes with a 4 person crew. Took one person to remove each bumper (we had 4), then each person could attach the blue fabric, then it would take 2 people to put each bumper back on (one pushing it in, the other placing the pins).
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 05-10-2010, 20:01
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
If you are using the kit frame material, I highly recommend the bumper brackets that are sold by AndyMark. They slide right over the frame rails and you drop a hitch pin or bolt through the holes. About 30 seconds to remove or replace a bumper. They are not cheap, especially if you are making 2 sets of bumpers, but are worth the investment.
The same technique can be used for non-kit frame rail materials, if you have access to a metal brake or a sponsor that can bend you some. One of my teams did that a couple years ago with great results. Or find some channel the right size and use that. That can also be done with the kit frame.
I'm not a big fan of permanently attached bumpers, I strongly recomend a solid, well thought out method that allows them to be removed and replaced easily. Keep in mind that the rules recommend that one person should be able to do the task in under 10 minutes. Also keep in mind that the bumpers have to be off the robot for weighing and sizing. You would not believe the number of robots that it takes an hour to try and put the bumpers back on.
When I give seminars, I emphasize that the bumpers need to be part of the design from the beginning, not something that is hacked on to the robot on ship day or at the regional. It's very obvious when inspecting a robot if this was the case or not. If you pay attention to what you are doing, that 3/4" slab of plywood can provide a lot of structural integrity to a lighter weight frame.
Also, if you are only going to have one set of bumpers, and looking good is important to you , making slip covers for each bumper that attach with snaps or velcro and fit snugly is strongly recommended. The elastic covers that were available last year came loose or got pulled off due to robot-to-robot interaction. Saw some penalties due to the bumper cover hanging down below the bumper zone. Duct tape and/or cable ties are not an acceptable method of trying to hold the cover back on. I know it's a pain to have to store them in the pit, but I recommend having two sets so you don't have to worry about covers coming off.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 05-10-2010, 20:13
alubin237's Avatar
alubin237 alubin237 is offline
FRC #0075 (Robo Raiders)
alubin237 is a glorious beacon of lightalubin237 is a glorious beacon of lightalubin237 is a glorious beacon of lightalubin237 is a glorious beacon of lightalubin237 is a glorious beacon of lightalubin237 is a glorious beacon of light
This past season we made two sets of bumpers. We put threaded inserts into the plywood. Then we attached the bumpers to the robot with thumb screws.
We attached the fabric to our bumpers with staples. We find that this works best. After we staple one side of the bumper we pull the fabric tight( a 2 person job) and staple it while gradually moving down to the ends of the bumpers. this leaves us with bumpers that are very tight. We like test them by flicking them if it is wrapped tight enough, you will hear a subtle drum like sound.
Unfortunately Im not sure what the best bumper design is that I've seen, there are alot of methods that have the same result.
Unread 05-10-2010, 21:10
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
our bumpers this year used wing nuts to attach, 2 people could change the colors in less than 45 seconds
Unread 05-10-2010, 21:33
maverickfan138's Avatar
maverickfan138 maverickfan138 is offline
Still hooked on FRC
AKA: Marc Antinossi
FRC #0573 (Mech Warriors)
maverickfan138 will become famous soon enoughmaverickfan138 will become famous soon enough
Our bumper design worked our extremely well for us this past year. We took some 3" angle brackets(placed in the corners) and screwed all four sides of our bumpers together in the permanent shape of the frame perimeter. We then added 1" angle brackets to attach our bumpers to the chassis. To put the bumpers on the robot, we would just slide the bumpers over the top, like how somebody would put on a t-shirt. To fasten, we drilled a hole in the 1" angle bracket and the chassis. We dropped a bolt with a loop of surgical tubing attached near the bolt head and looped the surgical tubing around the other end of the bolt. We did this on all four sides and it worked perfectly. With four students, we were able to change our bumpers in about 30 seconds.
The best bumper design that I saw this year were the ones with the folding fabric. They had Velcro on the top and bottom of the bumpers, and they would peel one side off and fold it(the seam ran horizontally along the middle of the bumper) to the other side, which was the opposite color.
2010 - 2011: FRC 573 student
2012 and beyond: MTU student, watching FRC from afar
Unread 05-10-2010, 21:39
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
My team used 80/20 stantions mounted to the kit rails and screwheads coming out of the plywood to fit into the 80/20. It was very secure and allowed for easy removal. For covers, we made a set that velcro'ed to the acutal bumpers. It was sturdy as well, but it might lack the visual wow factor you are looking for
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 05-10-2010, 22:37
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
We did the flip method with Velcro and to attach to the frame we used threaded rod type things that stuck in the wood and we put wing nuts on them. Very Sturdy and Easily removable for Weigh in.
Unread 05-10-2010, 22:43
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I thought our 2010 robot's bumper worked pretty well. One of our mentor took some time to cut and sew a red cloth cover for the main bumper, it was attached by two staples on the back I think. We had velcro and a blue cover since we didn't want to spend the time and resource to make another set that has to be reattached on and off during competition.
We had holes drilled into the robot and had bolts attached to the inside of the bumper so a wingnut could be fastened onto it and hold the bumper in place.
The blue cover wasn't asthetically nice to have on, and putting velcros on the red bumper probably didn't help, but we encountered no problems with it.
Unread 06-10-2010, 00:08
We had two sets of bumpers, with a very similar attachment method to this. We used the same pins, but used 1" ID C stock and put that around 1" x 2" tube stock. We then drilled a hole through both pieces of metal, through all 4 walls. We then dropped the pin through the hole. We could take a bumper off in 5 seconds, and put another one on in 15 seconds. If we have bumpers again next year, that's how we are going to do it again.
Unread 06-10-2010, 07:25
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
All these methods work well. BUT, the VERY BEST way to construct and mount bumpers is in strict accordance with the 2011 FRC Manual.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 06-10-2010, 07:59
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Team 148 had a one-piece bumper (1 red and 1 blue), that fit perfectly over the frame of their robot. I watched them change it out, and it only took them about a minute to do it. It was also made out of a very slick material, so it would 'slip' off an opponent's bumper.
Very cool!
Unread 06-10-2010, 08:09
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Best or easiest? I'd go with easiest for bumpers any day.
Our team attached our four bumpers together with angle brackets to make one large bumper and then had corner plates that laid horizontal to the top of the robot frame and attached to the robot with wing nuts. Took 2-4 students around 20-30 seconds to install.
1058 PVC Pirates 2016 - xxxx
Unread 06-10-2010, 08:30
Pjohn1959's Avatar
Team 118 also had a one-piece (see photo).
The cool thing about them, was that they brought extras, and were giving them to teams that had not done their bumpers at Lonestar. They brought a big stack of them, but by the end of Thursday, they were all gone.
Unread 06-10-2010, 09:09
Brandon Holley's Avatar
This past year we used the flip method to change our bumpers which worked out pretty awesomely. Luckily we had a talented seamstress on the team that made the bumper covers for us that worked excellently all season.
As for mounting them, we used L brackets to hug the 1" box tubing that ran around the frame perimeter of our robot. We then just dropped a pin through the L brackets and the box beam. Took ~1 minute to remove all the bumpers from the robot.
Another cool thing we did in 2009 was use the same clips that hold brooms to a wall to hold the front bumpers to our robot. This was part of the rule that required 6" of bumper to be backed by a solid frame member. Because our robot had a wide intake in the front we wanted to minimize the bumper/frame member required to do this. Below is what we ended up with. It worked out great, we never had a bumper fall off and they were literally snap on and snap off.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
What is the best way to ecure the FRP sheets to the carpet? 1120227 General Forum 1 06-01-2009 16:56
Whats the best way to catch the Loch Ness Monster? DanL Chit-Chat 52 01-02-2003 14:48
Sponsers: Whats the best way to pick THEM up? Wetzel Chit-Chat 2 06-05-2002 22:32
Girls: Whats the best way to pick you up? Wetzel Chit-Chat 305 06-05-2002 16:47
Whats the Best Web Page for FIRST You've Ever Seen? Joe Matt General Forum 5 14-02-2002 09:32
