Re: Replacement Battery for Classmate
it's highly unlikely that the problem is the battery, seeing as they're lithium-ion, they'll last longer than you will. are you sure that your charging it completely?
you might even be able to find a supplementary battery to extend the battery capacity |
| Spare Classmate Battery Sources, Charging Externally | kmcclary | Control System | 7 | 30-01-2012 12:10 |
| 911; CLASSMATE BATTERY Not Reconized and Not Charging!! | Must Be Drama | FRC Control System | 1 | 08-03-2010 20:22 |
| Replacement for FP 15 tooth gear? | grosh | Motors | 1 | 12-02-2010 15:05 |
| Classmate battery not working? | lookitsnichole | Control System | 1 | 10-02-2010 00:01 |
| Battery Charger for long term battery care | DougHogg | Kit & Additional Hardware | 0 | 08-02-2003 15:25 |
