Go to Post As for the rain... I got to test out my umbrella hat last year. Turns out, it actually works...until the wind blows it off. - Barry Bonzack [more]
Unread 04-10-2010, 14:06
nealpatel nealpatel is offline
FRC #1777
nealpatel is an unknown quantity at this point
Replacement Battery for Classmate
I was wondering that since our Classmate PC's are still under 1 year warranty period, can we order a replacement battery for it?
I am not sure if you can do that but just want to make sure as our battery doesn't last long enough.
If not, is there any other place where I can get a cheap battery for the Classmate?
Thank You,
--- Neal Patel
--- Team 1777, Viking Robotics.
Unread 05-10-2010, 19:27
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Replacement Battery for Classmate
it's highly unlikely that the problem is the battery, seeing as they're lithium-ion, they'll last longer than you will. are you sure that your charging it completely?
you might even be able to find a supplementary battery to extend the battery capacity
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 05-10-2010, 20:02
On the Control System Page it has a link to the support page for where you could request warranty service. I do not know if the battery is covered, as they often have different terms.
You could also buy a replacement battery. http://www.ctlcorp.com/v4/p-811-6-ce...leron-eo9.aspx
Lithium-ion batteries are actually one of the worst types of batteries for long term usage. See http://www.batteryuniversity.com/parttwo-34.htm
Aging of lithium-ion is an issue that is often ignored. A lithium-ion battery in use typically lasts between 2-3 years. The capacity loss manifests itself in increased internal resistance caused by oxidation. Eventually, the cell resistance reaches a point where the pack can no longer deliver the stored energy although the battery may still have ample charge.
Spare Classmate Battery Sources, Charging Externally kmcclary Control System 7 30-01-2012 12:10
911; CLASSMATE BATTERY Not Reconized and Not Charging!! Must Be Drama FRC Control System 1 08-03-2010 20:22
Replacement for FP 15 tooth gear? grosh Motors 1 12-02-2010 15:05
Classmate battery not working? lookitsnichole Control System 1 10-02-2010 00:01
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
