Go to Post Hey, SHIFT HAPPENS.... - David Kelly [more]
Unread 05-10-2010, 21:53
Re: Several questions (language comparison)
Originally Posted by Radical Pi View Post
Team 639 used a rotating kicker and had a IR sensor that pulsed a Digital Line whenever the kicker reached a certain angle.
Why did you need an ISR to handle this? Was 20ms not fast enough?
Unread 05-10-2010, 22:46
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Our kicker rotated and launched outward when the kick button was pressed. The rotations were at an extremely high speed. To prevent the kicker from coming out at an unpredictable and generally unfavorable angle, we used the sensor as an interrupt to make sure the kicker could come out at a predictable angle. As the speed of the rotator increased, the range of angles for a good kick decreased, so the room for error in the timing of the code wouldn't allow for timing of the kick to occur in the main loop. The interrupt checks a flag for whether to kick, and also will delay the kick as needed to compensate for the speed of the kicker (without the extra timing code, the kicker only works around 75% power)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 05-10-2010, 23:07
What is the worst-case execution time of the ISR from the time it receives control until it returns? Do you enable interrupts in the ISR, or leave them disabled?
Unread 05-10-2010, 23:20
AKA: Ian Thompson
I'm not sure of the exact number as I didn't write the timing code for it, but I think the time to run it is almost nothing. The only slow operation is the wait to delay the kick, but that would be a very small wait.
The interrupt is setup through WPILib, so I have no idea if interrupts during interrupts are enabled (never seen any problems though).
Unread 06-10-2010, 00:20
When you say "very small" do you mean, say, a few microseconds?
Or are you talking milliseconds?
Unread 08-10-2010, 12:18
AKA: Ian Thompson
I think it's in the single digit milliseconds, but again I'm making a guess from the speed of our kicker
Several questions... elbuo NI LabVIEW 0 16-02-2010 02:14
joystick comparison within percentage IceStorm NI LabVIEW 4 20-03-2009 00:19
Aluminum sprockets for drive train - several questions M. Mellott Technical Discussion 16 16-12-2008 15:53
Several questions Amittt 3D Animation and Competition 8 02-02-2006 18:21
Comparison Paper ? Steve W General Forum 13 09-11-2004 16:37
