Thread Tools |
Rating:
Display Modes |
#7
Re: pic: Broken Output Shaft
Those grooves cut into the shaft are a HUGE no-no is shaft design. It probably didn't help that there was a hole drilled through the middle, but those grooves are big stress risers where the shaft is experiencing the most stress.
| Gearbox Output Shaft Defect | Nathan2974 | General Forum | 2 | 16-01-2010 10:26 |
| roll pin into output shaft | m1k3 | Kit & Additional Hardware | 18 | 15-01-2008 16:18 |
| diameter of transmission output shaft | sj31419 | Electrical | 5 | 17-02-2005 22:09 |
| Cutting the output shaft | Kevin A | Technical Discussion | 2 | 18-02-2003 01:47 |
