Go to Post I found another student once at a Cross Country meet because she was wearing a team shirt. I must say, I was surprised. I should start wearing my team shirt around more often. - TheBoulderite [more]
Unread 07-10-2010, 20:45
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Dust Collection Systems
Originally Posted by Greg Needel View Post
A shop vac is not a dust collector, actually they are not even in the same ball park
Greg, can you elaborate on this a little bit more? At home, I use my shop vac as a dust collector for my band saw and belt sander, moving the hose from tool to tool. I have found that some particles remain in the band saw housing, and the suction at the belt sander is so high that I have lost workpieces into the vacuum box. It's nothing like my Dad's shop, where he has a decent 'particle collector' (with filter bags in the several dozen micron range) but it's in a different section of the shop so we're not breathing it. That system (hard-plumbed, with automatic-switching blast gates) works pretty nicely.
Unread 09-10-2010, 10:59
REVving up for a new season
FRC #2848 (All-sparks)
Sure. From a systems standpoint the main difference is that in a dust collector all the particles go through the impeller while in a shop vac the motor/blower is separated by the filter from the debris tank. There are a few reasons these systems are designed differently and it significantly impacts the way the tool should be used.
CFM and in of water - You can easily compare them to speed and torque. CFM is the velocity of the air, and just like in a robotic system the higher the speed the less torque. For dust collection because all of the particles are small with essentially 0 mass they get caught in the airflow and sucked into a dust collector. The smallest Dust collectors are ~ 600CFM while the best industrial "shop vac" I have ever tested was 180CFM (it cost ~$3000). Inches of water is the vacuum pressure or the torque of the system, it does the heavy lifting. Most shop vacs are designed for general cleanup where they will be picking up piles of dust, wood chips, water, etc so the airflow does not need to be high. The highest static pressure I ever tested on a industrial vac was ~90inches of water which was really incredible for a portable unit. Dust collectors are in the 2-3 inches of water. The reason this is important has to do with the tasking of the different machines. If you are focused on sawdust specifically a shop vac will do a good job of picking up the piles after you are done working, but while the machine is generating dust it just does not have the airflow required to redirect the particles into the vac.
The other major difference between the two is safety. The main reason to have a dust collector (beyond keeping a clean shop) is keeping those tiny particles of wood (10microns or less)out of your lungs to avoid things like obstructive pulmonary disease (COPD) and increased risk of cancer. For this dust collectors are WAY better regardless of if you have a HEPA or other really good filter on your shop vac, as it all comes down to filter placement. Since the filter is after the impeller on dust collectors every particle which is in the air caught by the collector hits the filter. The same can be said for the particles in a shop vac in the stream, but unfortunately the motors in shop vacs are also cooled by air, which is sucked in from the side of the unit and expelled again without passing through a filter. This can basically hyper accelerate the sawdust into the air making it a bad situation not just around the machine but anywhere else with open airflow to your workshop.
Additionally it is important to note that the amount of filter material in the system impacts performance over time because people forget to change/clean their filters. I am guessing but I would say that the average shop vac filter has 20times less the filter capacity than a dust collector which means longer running in between filter blinding. While you can get good filters for shop vacs the average one will be much lower in quality and rating (allows larger particles through) than a dust collector filter bag.
Like I said in my earlier post I could go on talking about this topic for quite a while but those are the major differences. As always your mileage may vary based on each situation you are in, but I hope this helps. I am an advocate of using the correct tool for the job and while you can get a 4"inch adapter to connect your table saw to a shop vac you will probably be better with no dust collection and picking up the piles later.
Greg
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-10-2010, 15:02
DonRotolo's Avatar
Back to humble
FRC #0832
OK, so the CFM issue is likely the main reason why the shop vac doesn't do a good job collecting all the dust from the sander, for example. It certainly has the 'torque' (vacuum in inches of water) to pull in what it can capture, but the capture range is very small because of the low 'speed' (CFM air movement).
Now I get it.
Maybe I can steal my Dad's system while he's not looking....
Unread 09-10-2010, 18:45
Now I get it.
you could always buy one of these http://www.deltaportercable.com/Prod...roductID=24010
it's the one I designed while still at black & decker.
Unread 10-10-2010, 12:26
Dick Linn's Avatar
no team (Synergy)
ow do the 50-786 and 50-760 compare?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 10-10-2010, 18:36
same performance specs, but the usability (moving around , bag changes, etc) and the structural stability are better with the 50-786.
Unread 10-10-2010, 19:46
Dick Linn's Avatar
no team (Synergy)
Still using the proprietary bags I suspect. Ah, well, that's the way of things I guess. I saw that the -760 had some complaints about the upper bag hanger ferrule/mount. Wonder if that has been addressed?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 10-10-2010, 19:52
Nothing was done to the upper filter bag mount, we actually encourage people to get the canister filter, as it is WAY better. As for bags, you can use any garbage bag you want (i recommend thick ones like construction trashbags), but the unit is supplied with 2 bags which are meant to be dumped reused.
Wanted: Space-Age Dust Removal JohnBoucher NASA Discussion 15 01-05-2008 09:02
Mars dust storms suck life out of rovers JohnBoucher NASA Discussion 27 04-09-2007 19:58
Dust iamnafets 3D Animation and Competition 1 19-02-2004 18:27
Team 398 lost in the dust? kellyG Robot Showcase 1 29-03-2003 22:44
pic: Another one bites the dust! CD47-Bot Extra Discussion 1 14-03-2003 08:40
