| I'd flip my normals for you. |
pic: Belt Drive Chassis Take 2
Re: pic: Belt Drive Chassis Take 2
This path looks strange but I don't see why it wouldn't work. If you're really pushing it, you can fit 2 separate timing belts in a 2x1 tube. Here's 1625's scarily similar prototype: http://www.chiefdelphi.com/forums/sh...ad.php?t=86668
I don't know how you have modeled your belt in inventor (whether it includes the teeth in the width or not). If you have not included the teeth in the thickness of your belt I'd caution how close the teeth would be to each other near the idler left of the center wheel.
Also worth noting here that specing a belt to the exact length needed may be a bit more difficult because the belt is following an irregular path. Shouldn't be too hard to figure out, but you may have to end up rounding your belt size up or down and relying on the idlers to tension. -Brando |
That's a 2"x1.5" tube Chris
With a toothed belt (or chain), I see problems arising when there are multiple, non-continuous contact patches with the pulley (like with the center wheel in the configuration shown).
For the sake of argument, say the top part of the belt is fully engaged with the teeth at the top of the center pulley. Clearly, you also want the other contact patch to be fully engaged with the teeth of the center pulley. Let's say your pully has 40 teeth, and 10 of them are engaged with the top of the belt. Then there are 10 unengaged teeth (the gap between where the belts contact the pulley), then 10 teeth engaged with the bottom of the belt. In this configuration, there must be an integer number of teeth in the belt between where it leaves the top of the center pulley and returns to the bottom (since there is an integer number of teeth on the pulley between the same two points*). How do you ensure this? You either design for the exact right belt length, or you add adjustment to your system. You already have a tensioner, but, depending on belt pitch, you may need more than one dimension of adjustment in order to find both a belt length and belt tension that work. Failing that, I could see (best case) uneven loading of the belt and (worst case) belts skipping out of their pulleys. I hope that all made sense. * There could of course be, say, 9.5 teeth between contact patches, in which case the requirement generalizes to X.5 teeth in the belt, etc. |
Have you experienced a issue like this or are you just making a well educated guess (theory)? |
#7
#8
-Brando |
#9
Ok. That is a good image. Thank you. I have a idea to work around that. Thanks.
#11
I have been trying to figure out how to do that. What size belt were you using?
Did you have to make custom pulleys? |
#12
My concern is the moving tensioner. Any time the load on the belt gets high enough, the whole belt will move the movable tensioner, and there will be slack somewhere in the belt.
Somewhat like chains, enough slack and the belt will slip over the sprockets. Very UNlike chain, teeth will pop off the belt when this happens. Don't ask how we know this. In Aim High, we used a belt that was subject to high and variable loads, and had a spring-loaded tensioner. You do the math. |
#13
as long as the belt has an even number of teeth, and the distance between the center to the two outer pulleys is exactly equal, the teeth will line up on top and bottom.
oh, and the number of teeth on the center pully must also be even Last edited by Hawiian Cadder : 07-10-2010 at 21:24. Reason: realized i was wrong |
#14
We used 172 tooth 9mm wide Gates 5mm GT2 belts. We did not use custom pulleys. Our pulleys were 19 tooth GT2 pulleys.
#15
Were you happy withe the 9mm wide belts? I have been thinking about going to the 15mm wide 5mm pitch belt, but they are huge.
| pic: Belt Drive Chassis | Sh1ine | Extra Discussion | 11 | 07-10-2010 07:11 |
| pic: Schreiber Take on West Coast Drive | Andrew Schreiber | Extra Discussion | 69 | 23-08-2010 00:36 |
| pic: FRC488 - Six Wheel Drive Chassis | Madison | Technical Discussion | 38 | 23-01-2007 10:58 |
| Chain drive vs. cogged belt drive(timing belts) | LordBritten | Technical Discussion | 24 | 20-12-2006 23:07 |
| pic: Belt drive 1559 | krADLEY | Robot Showcase | 8 | 01-02-2006 21:37 |
