[FTC]: Tether Testing
Hey, anyone know how, or can provide instructions on how to test the 2010 FTC robot tethered to our computer? Our wireless isn't working and we want to test out our programming to see if it works correctly.
Re: [FTC]: Tether Testing
Just connect the USB-A to USB-B cable to the brick and your computer and you should be able to connect just fine. Also if wireless isn't working, it is a problem you need to figure out, but you can always use bluetooth like in past years, there should be no difference in the robots behavior between these three choices.
Hope that helps |
| [FTC]: FTC Futures Forum at FTC World Championship | gdo | FIRST Tech Challenge | 0 | 08-04-2009 18:46 |
| [FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) | Mr. Lim | FIRST Tech Challenge | 2 | 03-03-2008 11:54 |
| Tether | ttldomination | VEX | 11 | 20-01-2008 18:58 |
| [FTC]: [FTC]: Ontario Provincial FTC Start/End Times | cbhl | FIRST Tech Challenge | 8 | 16-12-2007 13:37 |
| tether | edomus | Technical Discussion | 7 | 06-03-2004 20:04 |
