Go to Post Spoiler: There will be no plasma cutters available in FIRST Choice - Jibsy [more]
Unread 07-10-2010, 21:26
jaster67 jaster67 is offline
Jose Sanchez
FTC #2978 (Cavaliers)
jaster67 is an unknown quantity at this point
[FTC]: Tether Testing
Hey, anyone know how, or can provide instructions on how to test the 2010 FTC robot tethered to our computer? Our wireless isn't working and we want to test out our programming to see if it works correctly.
I will give you a million dollars if you don't read this sig.
Unread 08-10-2010, 00:26
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: [FTC]: Tether Testing
Just connect the USB-A to USB-B cable to the brick and your computer and you should be able to connect just fine. Also if wireless isn't working, it is a problem you need to figure out, but you can always use bluetooth like in past years, there should be no difference in the robots behavior between these three choices.
Hope that helps
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
[FTC]: FTC Futures Forum at FTC World Championship gdo FIRST Tech Challenge 0 08-04-2009 18:46
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
Tether ttldomination VEX 11 20-01-2008 18:58
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
tether edomus Technical Discussion 7 06-03-2004 20:04
