Go to Post Is the bottom slot just to make the whole thing look like a smiley face, or is it functional? - Chris is me [more]
Unread 07-10-2010, 11:30
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
pic: Belt Drive Chassis Take 2
Unread 07-10-2010, 11:31
Chris is me's Avatar
AKA: Pinecone
Re: pic: Belt Drive Chassis Take 2
This path looks strange but I don't see why it wouldn't work. If you're really pushing it, you can fit 2 separate timing belts in a 2x1 tube. Here's 1625's scarily similar prototype: http://www.chiefdelphi.com/forums/sh...ad.php?t=86668
Unread 07-10-2010, 11:52
Brandon Holley's Avatar
I don't know how you have modeled your belt in inventor (whether it includes the teeth in the width or not). If you have not included the teeth in the thickness of your belt I'd caution how close the teeth would be to each other near the idler left of the center wheel.
Also worth noting here that specing a belt to the exact length needed may be a bit more difficult because the belt is following an irregular path. Shouldn't be too hard to figure out, but you may have to end up rounding your belt size up or down and relying on the idlers to tension.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 07-10-2010, 11:58
Aren_Hill's Avatar
Build Nifty Things
That's a 2"x1.5" tube Chris
A guy who likes robots.
Unread 07-10-2010, 12:23
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
With a toothed belt (or chain), I see problems arising when there are multiple, non-continuous contact patches with the pulley (like with the center wheel in the configuration shown).
For the sake of argument, say the top part of the belt is fully engaged with the teeth at the top of the center pulley. Clearly, you also want the other contact patch to be fully engaged with the teeth of the center pulley. Let's say your pully has 40 teeth, and 10 of them are engaged with the top of the belt. Then there are 10 unengaged teeth (the gap between where the belts contact the pulley), then 10 teeth engaged with the bottom of the belt. In this configuration, there must be an integer number of teeth in the belt between where it leaves the top of the center pulley and returns to the bottom (since there is an integer number of teeth on the pulley between the same two points*).
How do you ensure this? You either design for the exact right belt length, or you add adjustment to your system. You already have a tensioner, but, depending on belt pitch, you may need more than one dimension of adjustment in order to find both a belt length and belt tension that work. Failing that, I could see (best case) uneven loading of the belt and (worst case) belts skipping out of their pulleys.
I hope that all made sense.
* There could of course be, say, 9.5 teeth between contact patches, in which case the requirement generalizes to X.5 teeth in the belt, etc.
Unread 07-10-2010, 14:31
FRC #2791
The other mentor is concerned about the same thing. I am not sure that I completely follow you however. I am under the impression that if a belt has a 5mm pitch it is only a matter of turning a pulley (also with a 5mm pitch) to the correct orientation. And if that pulley has a 5mm pitch then the belt should match at all points, regardless of the path in between. But who knows, you answer sounds a lot better then mine. I have never been much of a math wiz.
Have you experienced a issue like this or are you just making a well educated guess (theory)?
Unread 07-10-2010, 14:32
FRC #2791
-Brando
I am not sure either, I just specified my belt in the Design Accelerator. Do you know if that takes the teeth into account? Also I have a belt specified for the application already. The length works with the tensioner.
Unread 07-10-2010, 15:58
Measure the thickness of the belt as Inventor is showing it and cross reference that with the thickness of the belt w/ and w/o teeth as per the manufacturer. You should get your answer pretty quickly that way.
-Brando
Unread 07-10-2010, 16:19
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
This is a real issue with any toothed belt or chain if you attempt to engage different locations of the same sprocket.
Art Dutra IV
世上无难事,只怕有心人.
Unread 07-10-2010, 19:36
FRC #2791
Ok. That is a good image. Thank you. I have a idea to work around that. Thanks.
Unread 07-10-2010, 19:41
FRC #2791
I have been trying to figure out how to do that. What size belt were you using?
Did you have to make custom pulleys?
Unread 07-10-2010, 20:36
DonRotolo's Avatar
Back to humble
FRC #0832
My concern is the moving tensioner. Any time the load on the belt gets high enough, the whole belt will move the movable tensioner, and there will be slack somewhere in the belt.
Somewhat like chains, enough slack and the belt will slip over the sprockets. Very UNlike chain, teeth will pop off the belt when this happens.
Don't ask how we know this. In Aim High, we used a belt that was subject to high and variable loads, and had a spring-loaded tensioner. You do the math.
Unread 07-10-2010, 21:23
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
as long as the belt has an even number of teeth, and the distance between the center to the two outer pulleys is exactly equal, the teeth will line up on top and bottom.
oh, and the number of teeth on the center pully must also be even
Unread 07-10-2010, 23:19
Carrington's Avatar
Carrington Carrington is offline
AKA: Carrington
FRC #1625 (Winnovation)
Carrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant future
We used 172 tooth 9mm wide Gates 5mm GT2 belts. We did not use custom pulleys. Our pulleys were 19 tooth GT2 pulleys.
Unread 07-10-2010, 23:24
FRC #2791
Were you happy withe the 9mm wide belts? I have been thinking about going to the 15mm wide 5mm pitch belt, but they are huge.
pic: Belt Drive Chassis Sh1ine Extra Discussion 11 07-10-2010 07:11
pic: Schreiber Take on West Coast Drive Andrew Schreiber Extra Discussion 69 23-08-2010 00:36
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Belt drive 1559 krADLEY Robot Showcase 8 01-02-2006 21:37
