Go to Post FIRST is about the relationships you build. ONE individual at a time. - xitaqua [more]
Unread 08-10-2010, 00:50
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
Re: pic: Belt Drive Chassis Take 2
The TENSION required to transmit the driving force will be a function of degrees of wrap around the cog not the number of teeth engaged. This is because driving force creates a force that lifts the belt away from the cog. It will take less belt tension to transmit a given force for a single segment wrapped twice as far then the 2 segments shown. This is assuming the tooth phasing problem mentioned above is solved. One more note. I have never seen this configuration used or recommended. It is a clever thought, but likely wont yield the hoped for result.
When you evaluate variations like this always look at the forces generated and if EXTRA structure has to be added to deal with those forces.
Unread 08-10-2010, 07:33
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
Originally Posted by Hawiian Cadder View Post
as long as the belt has an even number of teeth, and the distance between the center to the two outer pulleys is exactly equal, the teeth will line up on top and bottom.
oh, and the number of teeth on the center pully must also be even
I believe that this holds only as long as the center pulley has an even number of teeth.
Unread 08-10-2010, 21:26
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
that was in the edit, i realized that moments after submitting the reply.
Unread 08-10-2010, 23:02
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Originally Posted by Sh1ine View Post
Were you happy withe the 9mm wide belts? I have been thinking about going to the 15mm wide 5mm pitch belt, but they are huge.
Have you looked at the loading on your drive, to know what size belt you need? The Gates site has several design tools to help you with the evaluation. You might be surprised at the capability of the 9mm belts.
Also, is there a reason that you don't want to use two belts, instead of a single belt? It is a much simpler design, but I don't know what design constraints you are working with. Just curious.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 08-10-2010, 23:09
Chris is me's Avatar
AKA: Pinecone
The main constraint is that the team wants to keep the belts inside the AL tube - right now it's sized at 3x1.5 inches I think? I'm pretty sure it can be done with a 9mm belt.
Unread 09-10-2010, 10:19
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
There really is no reason. I starting off thinking that it would be easier to have one belt, and get the system in the tube. Now after reading everyones thoughts I think it is going to be harder. Did you have a spring tensioner in your system? Did you use steel pulleys or were you able to find Aluminum one? I can only find GT2 steel pulleys.
Unread 09-10-2010, 15:55
From a quick search on SDP-SI.com, I'm finding the following 9mm wide GT2 5mm timing belt pulley in Aluminum. FYI. There are plenty more like it.
A 6A55-032DF0916
Unread 09-10-2010, 16:00
FRC #2791
I was just reading the thread on your bot, and learned about your tensioner. Very ingenuous. Did you end up using a similar design for the game? How did the belts hold up over time?
Unread 09-10-2010, 16:05
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
SDP-SI sells lightweight sprockets for 5mm HTD timing belts that have a polycarbonate body and various styles of aluminum hubs. We used the 'Aluminum T-Insert' sprockets at the time (which we broached keyways into), but might consider Fairloc hubs for the future. Both of the mechanisms (the shooter and ball intake rollers) were high-speed, low(ish)-torque systems, so the lower torque capacity of HTD belts versus GT2 wasn't an issue. We didn't have any issues with the belts (or pretty much anything else) on our robot that year.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-10-2010, 14:58
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Reading this thread and a few other threads on the chain/belt compairison I see few spots where people talk of belts breaking, slipping or loss of the belts teeth/lugs. I don't understand. Maybe the small pitch belts from the Kit-of-parts would slip. Buy a better belt. Thinking of a car's timing belt or serpentine belt there is no way I would expect to see a failure in some belt like that on our robots.
I have also seen comments about robots pushing against each other and the chain one always wins over the belt. Saying the belt slipped. Here again if the correct belt is used and tensioned correctly etc I see no way that the contact patch between the wheels and carpeted floor could outlast a good belt.
I guess the real question is what type of belt is required for drive wheels?
Thanks--good luck to all in 2011
Unread 11-10-2010, 21:01
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
tres cool.
I'd suggest spring loading both of the chain tensioners equally. This should help the belt alignment issue on the middle wheel.
Putting this drive inside a rectangular tube is neat and will protect it. It will also make maintenance a bear.
I'd suggest prototyping after getting the design down. Look at maintenance ease an reliability in the prototype. Try to break it.
Good luck.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 11-10-2010, 21:12
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Originally Posted by Clem1640 View Post
Try to break it.
Don't just drive it around. Run it full speed over a bump and see if it survives on impact. Run it full speed into a solid object (e.g. not a freshmen, a wall works well) and see if you can break it. Keep it stalled against a wall to see if it breaks before the breakers trip (if properly designed, the wheels should slip and the belt should not. If neither slips, the breakers will trip after a few seconds. The belt should not slip ever). Try pushing some other robots around. Fight well.
Do this for a really really long time (at least a few batteries). Then you will know if it is good enough.
You might be surprised how much abuse it has to take.
Kettering Motorsports
Unread 15-10-2010, 14:14
Aren_Hill's Avatar
Build Nifty Things
That's a 2"x1.5" tube Chris
A guy who likes robots.
Unread 16-01-2012, 21:30
Crawler Crawler is offline
FRC #3749
Crawler is a jewel in the roughCrawler is a jewel in the roughCrawler is a jewel in the roughCrawler is a jewel in the rough
im going insane trying to figure out where i can get that tensioner, or even what its called, if that is the one for the belts that Gates gives us then please send a product number or something
Thanks
pic: Belt Drive Chassis Sh1ine Extra Discussion 11 07-10-2010 07:11
pic: Schreiber Take on West Coast Drive Andrew Schreiber Extra Discussion 69 23-08-2010 00:36
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Belt drive 1559 krADLEY Robot Showcase 8 01-02-2006 21:37
