Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Programming
Unread 10-10-2010, 13:46
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: [OCCRA]: OCCRA 2010 VEX Workshop OSTC-NE 06Oct10
Here are some updated instructions on how to update the Firmware into the new, VEX Cortex, microcontroller and joystick.
The IFI Firmware update is run from outside the EasyC V4 Cortex programming environment
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 13-10-2010, 11:54
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
1. I wasn't at the workshop this year. I went last year, and assumed I was good.
2. I read the PDF's you posted. You did some math on speed and torque. JVN has a really really nice design spreadsheet for rotary mechanisms (See JVN's Design Calculator http://www.chiefdelphi.com/media/papers/2059). I first calculated the aprox. needed gear ratios by hand, and punched them into the calculator. I assumed the weight of the mechanism was neutral because of counterforce (notice I didn't say counterweight?) and the motor would only have to drive the ball. I over-estimated the arm length since I hadn't actually built it yet, and it said with a BIG motor (which does around 17 n-m of torque, BTW, the JVN calc needs numbers in n-m's). It said it would work quite well, and gave me the loaded output speed and motor current draw. I built it. It works well. The numbers say I can go a little bit faster, but then it would be uncontrollably fast (And I am trying to do the feedback with only P if possible, but I might need D).
Just a friendly reminder to OCCRA teams: Do the math! Just because a mechanism is large does not mean it will move slowly! With bungee you can do it easily!
Kettering Motorsports
[OCCRA]: OCCRA 2010 VEX Field Diagram marccenter OCCRA Programming 0 15-09-2010 16:52
[OCCRA]: OCCRA OCT-NE 10/14/09 Basic VEX Workshop PDF marccenter OCCRA Programming 11 22-10-2009 21:51
[OCCRA]: OOCRA 2008 VEX Programming Workshop marccenter OCCRA Programming 0 14-09-2008 20:17
