Thread Tools |
Rating:
Display Modes |
Re: Broken Classmate, How to replace?
make (or buy) a short cable (maybe 4 inches) with male connector on one end and female on the other. Epoxy the male connector into the Classmate. (Obviously, be careful not to coat the electrical contacts with epoxy) |
If you can't fix the classmate for DOTD, use another small laptop. At WPI this year our team competed with two robots and used a Dell as our second OI.
We used a pigtail like Ether suggested, but just wired it tightly in to the vent holes on the bottom of the Classmate underneath the Ethernet port.
You can use a usb ether net adapter. And then use a pigtail so that doesn't get broken.
Explain what a pigtail is...?
The "pigtail" they are referring to is the short Ethernet extension cable mentioned in a previous post. |
| Where/how to purchase spare classmate | PhilBot | FRC Control System | 30 | 26-01-2011 00:12 |
| Broken Ethernet connection on Classmate | topgun | General Forum | 5 | 12-03-2010 16:20 |
| How to prevent broken ethernet port on DS | Bharat Nain | FRC Control System | 32 | 18-03-2009 11:25 |
| How fast have you broken stuff? | hihihiflcl81pig | General Forum | 16 | 25-01-2009 18:13 |
| Broken promises or BROKEN ROBOTS! | archiver | 1999 | 9 | 23-06-2002 22:18 |
