Go to Post From past experience members of our team insist on never trusting gravity. - Vash [more]
Go Back   Chief Delphi > Technical > CAD
Unread 06-10-2010, 21:07
Dodge it Ram it Dodge it Ram it is offline
FRC #1699
Dodge it Ram it is an unknown quantity at this point
Help
I do not have a 8" Mecanum but am trying to draw on in solid works can any one give me some Dims? or a good link to a draft of it. this would be a great help thank u steve
Unread 06-10-2010, 21:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Help
http://www.andymark.biz/mecanum8.html
under "downloads"
Unread 06-10-2010, 21:22
FRC #1699
Re: Help
Thank u but that does really tell me how long the rollers are and how much the plate twists and such
Unread 06-10-2010, 21:38
Re: Help
Solidworks does have a "Dimensions" tool. You might try using that.
Unread 06-10-2010, 23:53
MrForbes's Avatar
AKA: Jim
Re: Help
It's a scale drawing, print it out and measure the size of things, and use a protractor to find the angles.
Unread 10-10-2010, 15:06
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: Help
If you have the model, then I would use the Measure tool:
Hold the control key down. Select the bottom flat face. Select the top flat face. and the normal distance will appear in the lower right corner of the graphics windows.
In the Evaluate tab, select the Measure tool for more options to measure angles and calculate x-y-z dimensions on the fly.
If you are in the drawing, there are some automatic dimensioning tools that can be very helpful. We usually don't stress these techiques in education because we want you to learn how to dimension according to a standard - but "DimXpert" can save you lots of time. Assuming you are using 2010, insert your views into a drawing. Select the small black expand arrow from the Smart Dimension tool from the Annotation toolbar. Select DimXpert option. Now select a vertex. This is your datum. Select different geometry in the view, such as a hole or edge. SolidWorks will insert horizontal, vertical and diameter dimensions automatically referencing the datum.
Marie
Unread 11-10-2010, 11:58
FRC #1699
Re: Help
Thanks guys for the help
Unread 11-10-2010, 14:07
Re: Help
The roller axis should be 45 degrees from the plane of the wheel.
If you want a "bump-free" mecanum wheel, the contour of the rollers is important. Design help for the roller profile can be found here: http://www.chiefdelphi.com/media/papers/2390
Also the rollers should be long enough so that there is a slight overlap as one roller transitions to the next as the wheel is turning.
HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW rokenboker NI LabVIEW 9 05-02-2010 17:10
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
