Go to Post I like how we're trying to save weight when we came in at 95 pounds. - Chris is me [more]
Unread 04-10-2010, 20:52
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
No atan() method in FRC version of java
I am trying to program a swerve drive, and I need to use atan(), but netbeans always says it doesn't exist in my class. Yes I know there is getDirection() on the joystick, but I need to manipulate numbers after taking them from the joystick.
Thanks in advance
Alex
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 04-10-2010, 21:07
Jared Russell's Avatar
Taking a year (mostly) off
Re: No atan() method in FRC version of java
Alex:
Take a look in the com.sun.squawk.util.MathUtils package. There are implementations of many of the J2SE math functions, including atan() and atan2(), in there.
Unread 05-10-2010, 01:34
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Team 20 had the same problem. We ended up writing a Talyor approximation and reflecting it about the axis to produce our own atan2 function.
Unread 05-10-2010, 07:59
AKA: Alex
Originally Posted by Jared341 View Post
Alex:
What is the import line I need to use? I tried 'import com.sun.squawk.util.MathUtils;' and that did not work. I have yet to learn what Taylor series are in detail, so that would be a project for down the road.
-Alex
Unread 06-10-2010, 18:40
AKA: Alex
Ok well I figured it out. I needed to call MathUtils.atan(). I wasn't using MathUtils befroe. Thanks for the input though everybody.
-Alex
Unread 06-10-2010, 19:38
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
What are you using the atan() function for?
If you are going to have negative numbers for the input, it may be better to use atan2(x,y).
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 06-10-2010, 20:23
Did you mean to say atan2(y,x)? Or does Java really reverse the order like Excel does. Say it ain't so.
Unread 06-10-2010, 20:29
biojae's Avatar
Sorry, that was a typo.
Here is the actual function header:
double atan2(double y, double x) ;
Unread 09-10-2010, 14:59
AKA: Alex
I am using it to calcluate the desired angle of a wheel in a swerve configuration. I calculate the x and y components of the vector representing each wheel. Getting the magnitude (speed) is easy, but without atan, the angle was going to be a challenge.
-Alex
Unread 11-10-2010, 14:15
Taylor expansion is not the best tool to use for this purpose.
See the discussion about ATAN2 nonlinear model fitting here:
http://www.chiefdelphi.com/media/papers/2390
Unread 11-10-2010, 15:19
I spent the summer porting a fixed point math library to Arm's Thumb2 assembly, and learned a lot when I hit the arc-trig functions. At the high school level, suffice it to say that these functions are very-not-polynomials and therefore hate Taylor series expansions. At the college level, suffice it to say that if I ever teach numerical approximations the final exam will be to approximate arcsine.
Java Simulator for FRC feverittm Java 3 27-04-2010 03:52
Java VisonChaser method Robototes2412 Java 0 15-02-2010 15:19
Java FRC API davidthefat Java 3 11-02-2010 06:49
Event Driven Development for FRC-Java spartango Java 5 05-01-2010 11:52
FRC Java 2010 Documentation alivemyst Java 11 07-09-2009 19:03
