Go to Post The GDC is becoming sane. - Zuelu562 [more]
Unread 13-10-2010, 00:43
tdressel tdressel is offline
FRC #1111
tdressel is an unknown quantity at this point
Re: [FTC]: Short USB cables for Samantha Module
Originally Posted by biojae View Post
This will be interesting (samantha), I wonder if programming can be done over it.
If not, then it will be the reverse of previous years.
Previous: Program over USB (during comps, so it doesn't disconnect from the FCS) and drive over bluetooth
Now: Program over bluetooth, then drive over USB (through samantha)
We are at a point where we can communicate with the Samantha unit but can get LabVIEW to see the NXT via the Samantha unit. Have you been able to program to the NXT via the Samantha unit - or do you have to still use the USB cable?
-Ted Dressel / Programming Mentor
Ted Dressel, Mentor, Team 1111
[FTC]: Tetrix Battery Pack Internal Short Circuit charrisTTI FIRST Tech Challenge 9 21-10-2009 11:40
[FTC]: USB controler problems VeedotJaydot FIRST Tech Challenge 3 04-02-2009 17:59
Reason for jaguar short? easponge FRC Control System 4 18-01-2009 15:09
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
