Go to Post everyone here has a life outside of FIRST (some just don't want to admit it). - shyra1353 [more]
Unread 13-10-2010, 08:17
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Labview run window help
So whenever i press the "run" arrow on top of say robotmain.vi i do not get the "Deployment Process" window that i use to get. Now when i click "run" the program just runs without doing any kind of deploying. How do i get that back help plz
Tnx
1514 Whci Robotics
Unread 14-10-2010, 06:26
Re: Labview run window help
The LV project window lets you have multiple targets within the window, and depending on where you open the VI from, it is pointed to that target. I suspect that the VI being run was opened from the host or My Computer, which means to run locally rather than on a remote target.
Greg McKaskle
Unread 14-10-2010, 09:21
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Also remember to open the Project you are working from and then open the RobotMain.vi What you are describing will happen if you open the RobotMain.vi by itself. I think I've had students do this before.
HELP I'm Losing it! aka Labview deploy vs. run kngscrpn24 NI LabVIEW 12 20-02-2011 23:41
[FTC]: How to run servos with LABview? Putney FIRST Tech Challenge 0 14-01-2010 12:05
Robot Run 5K Run/Walk - fundraise or come for the fun Carol Fundraising 0 06-03-2009 16:14
Using Run in Labview cabbagekid2 FRC Control System 5 07-01-2009 13:05
Can you run a Window Motor on a victor Noah Melamed Electrical 1 07-02-2004 16:11
