Go to Post The Glass is Half Full - Optimist.......The Glass is Half Empty - Pessimist.......The Glass is too Big - Engineer - mpking [more]
Unread 12-10-2010, 15:59
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Re: Help with PSoC board programming please
another problem is when i use
DriverStationEnhancedIO &dsio = DriverStation::GetInstance()->GetEnhancedIO();
i get the warning that "dsio" is an undeclared variable
any one knows how to fix this problem?
Unread 12-10-2010, 16:08
Try it without the "&" character.
Unread 12-10-2010, 16:22
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
i did that but I build it, i get an error this time
Unread 13-10-2010, 17:40
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
You're probably trying to use the variable outside of the scope it was declared. Is that code from your init function?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 14-10-2010, 22:30
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
I do not know what do you mean by init code?, I put it under teleoperated
Unread 15-10-2010, 16:45
AKA: Ian Thompson
init as in the constructor function (possibly called RobotDemo)
Can you post your full code? Also does it say the error is on the same line as the line you posted?
Unread 20-10-2010, 11:20
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
#include "WPILib.h"
#include "DriverStation.h"
//#include "Vision/HSLImage.h"
//#include "Vision/AxisCamera.h"
* This is a demo program showing the use of the RobotBase class.
* The SimpleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
/// CLASS ///
class RobotDemo : public SimpleRobot
Victor *VictorPair1, *VictorPair2;
RobotDrive *myRobot; // robot drive system
Joystick *RightStick, *LeftStick, *ThirdStick; // only joystick
DriverStation *ds, *dsio; // driver station
Servo *Left_GearServo, *Right_GearServo;
Victor *Dribbler, *CamKicker, *Winch;
DigitalInput *limitSwitchB, *AutoSwitch1, *AutoSwitch2, *AutoSwitch3, *Swltch;
Relay *ArmRelease;
// AxisCamera *camera;
/// PUBLIC ///
public:
RobotDemo(void)
VictorPair1 = new Victor(1);
VictorPair2 = new Victor(2);
ds = DriverStation::GetInstance();
myRobot = new RobotDrive(VictorPair1, VictorPair2); // create robot drive base
RightStick = new Joystick(1);// create the joysticks
LeftStick = new Joystick(2);
ThirdStick = new Joystick(3);
AutoSwitch1 = new DigitalInput(1);
AutoSwitch2 = new DigitalInput(2);
AutoSwitch3 = new DigitalInput(3);
limitSwitchB = new DigitalInput(7);
Left_GearServo = new Servo(3);
Right_GearServo = new Servo(4);
Dribbler = new Victor(5);
CamKicker = new Victor(6);
Winch = new Victor(7);
ArmRelease = new Relay(1);
GetWatchdog().SetExpiration(100);
/// AUTONOMOUS FIRST ZONE ///
void Autonomous(void)
GetWatchdog().SetEnabled(false);
Right_GearServo->Set(127);
Left_GearServo->Set(127);
if (AutoSwitch1->Get()== 1)
myRobot->Drive(-0.5, 0.0);
Dribbler->Set(1.0);
Wait(1.5);
myRobot->Drive(0.0, 0.0);
CamKicker->Set(-1.0);
Wait(1.0);
CamKicker->Set(0.0);
Dribbler->Set(0.0);
while(limitSwitchB->Get()== 0)
if (limitSwitchB->Get()== 1)
//////SECOND ZONE/////
if (AutoSwitch2->Get()==1)
myRobot->Drive(-0.30, 0.0);
Dribbler->Set(1.0);
Wait(2.6);
Wait(1.0);
Dribbler->Set(0.0);
Dribbler->Set(1.0);
Wait(1.2);
Wait(1.0);
Dribbler->Set(0.0);
//////THIRD ZONE//////
if (AutoSwitch3->Get()== 1)
Dribbler->Set(1.0);
Wait(1.3);
Wait(1.0);
Dribbler->Set(0.0);
Dribbler->Set(1.0);
Wait(1.2);
Wait(1.0);
Dribbler->Set(0.0);
Dribbler->Set(1.0);
Wait(1.3);
Wait(1.0);
Dribbler->Set(0.0);
myRobot->Drive(1.0, 0.0);
Wait(0.5);
/// OPERATOR CONTROL ///
void OperatorControl(void)
//GetWatchdog().Feed();
/* while (IsOperatorControl())
AxisCamera &camera = AxisCamera::GetInstance();
camera.WriteResolution(AxisCamera::kResolution_640 x480);
camera.WriteCompression(20);
camera.WriteBrightness(0);
// Assume that the THIRDSTICK THROTTLE is initially set at 100% (max)
// float Max_DribblerSpeed = ThirdStick->GetThrottle();
/// Robot Drive ///
myRobot->TankDrive(RightStick, LeftStick);
/// Dribbler Control ///
if (ThirdStick->GetRawButton(2))
Dribbler->Set(1.0);
/// ARM CONTROL ///
/// ARM RELEASE ///
if (ThirdStick->GetRawButton(6))
ArmRelease->Set(Relay::kForward);
Winch->Set(0.0);
Dribbler->Set(0.0);
else if (ThirdStick->GetRawButton(7))
ArmRelease->Set(Relay::kReverse);
Winch->Set(0.0);
Dribbler->Set(0.0);
else
ArmRelease->Set(Relay::kOff);
/// WINCH ///
if (ThirdStick->GetRawButton(11))
Winch->Set(1.0);
Dribbler->Set(0.0);
else if (ThirdStick->GetRawButton(10))
Winch->Set(-1.0);
Dribbler->Set(0.0);
else
Winch->Set(0.0);
/// CAMKICKER && LIMITSWITCH-B ///
if(ThirdStick-> GetRawButton(4))
while (limitSwitchB->Get()== 0)
Dribbler->Set(0.0);
Winch->Set(0.0);
if (ThirdStick->GetTrigger() && (limitSwitchB->Get()== 1))
Winch->Set(0.0);
Dribbler->Set(0.0);
if (limitSwitchB->Get() == 0)
/// GEAR CONTROL ///
if ( (LeftStick->GetTrigger()) )
Left_GearServo -> Set(127);
Right_GearServo -> Set(127);
if ( (RightStick->GetTrigger()) )
Left_GearServo ->Set(-127);
Right_GearServo ->Set(-127);
START_ROBOT_CLASS(RobotDemo);
Unread 20-10-2010, 17:19
AKA: Ian Thompson
You're defining dsio twice in your program. At the top of the file it is declared as a DriverStation*. Remove that (leave ds in there though) at it should build.
Unread 21-10-2010, 19:54
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
Yea, but even when I take it out of class, i get the same warning
Help with PSoC board wiring please krudeboy51 Electrical 1 04-05-2010 16:17
Attaching Psoc Board to breadboard nickcvet89 FRC Control System 2 10-03-2010 12:27
Windows "Malfunctioning USB Device" error with Psoc IO Board WarrenPW FRC Control System 2 11-02-2010 18:53
Wiring Switches to the PSoC board Raj1977 Electrical 13 07-02-2010 23:24
Help with programming new controllers, please. Oumonkey Programming 6 30-11-2006 21:53
