Go to Post Rules from prior years DO NOT APPLY to this year! - dlavery [more]
Unread 18-10-2010, 11:38
Joining the 900 Meme Team
FRC #0079
Re: CIM + Banebots P60 Gearbox
Originally Posted by Geek 2.0 View Post
No reason other than being REALLY cheap. Robots are expensive, and I want one, but I don't want to spend a lot on it. Gearboxes are the most expensive part, so we'll see...
Build a smaller one. Something sitting in the 30lb range should cost you ~$400 or so if done right. An FRC scale robot is actually quite a large machine.
BaneBots P60 + FP motor tips Rob Motors 15 04-02-2012 21:00
p60 gearbox disassembly KNZ1030 Technical Discussion 4 02-02-2009 11:07
Banebots/Cim motor programming question Japper Programming 4 14-02-2007 12:02
Strange noises from the BaneBots gearbox/CIM combination. PhilBot Motors 5 15-01-2007 11:15
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
