Go to Post When twenty people tell you your hair is on fire, you don't need to look into a mirror to find out they're right. - IndySam [more]
Unread 11-07-2010, 02:04
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
BugFix for CANJaguar code.
I could not find a way to submit a patch on the FIRST Forge tracker.
So, I am posting this here, and emailing it to the maintainers listed on FIRST Forge.
[edit]I'll also cross-post to the USFIRST forums once I get the email reminding me what my password is. The system isn't liking me, so if anyone wants to cross-post for me, that's fine.[/edit]
I have created a modified version of the CANJaguar code for Java, that
fixes Bug artf1172, which causes to the JVM to throw an exception and
stop on any IO error on the CAN bus. Several of you have commented on this in the WPILIB feedback thread.
To do this I basically threw IOExceptions instead of runtime exceptions.
This shoves error handling closer to the user, breaking source
compatibility.
Since the user must now handle exceptions themselves, breaking
source-compatibility. For this reason, I have also created the class
SafeCANJaguar, which handles all exceptions for the user, preserving
source compatibility.
Since I feel that I do not have authority to publish to
edu.wpi.first.addons, and to avoid confusion do to incompatible changes,
I have moved the files to `org.mckenzierobotics.CAN'.
http://lukeshu.ath.cx/CANJaguar for ...7.11.01.44.zip
Unread 18-10-2010, 17:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: BugFix for CANJaguar code.
Join the CANJava project and then you can post.
Unread 18-10-2010, 19:37
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
You don't even need to join the project... you just need to login to FIRST Forge.
Unread 24-10-2010, 03:01
Originally Posted by LukeS View Post
Your link is bad. Please log into firstforge.wpi.edu and create a new tracker for this and directly attach the file to the tracker. Here's a link to the Java tracker for CAN Jaguar: http://firstforge.wpi.edu/sf/tracker...aguar_for_java
-Joe
Unread 24-10-2010, 09:42
The new link is http://lukeshu.ath.cx/1/FRC/files/CA...7.11.01.44.zip
CANJaguar code with synchronization taichichuan CAN 5 06-05-2010 13:23
CANJaguar vi's RoboGuy Programming 15 18-04-2010 02:23
Potential Issue with the C++ CANJaguar Implementation mattbutts C/C++ 2 19-02-2010 13:26
CANJaguar for C++: Missing mode init messages? Abrakadabra CAN 2 14-02-2010 01:18
CANJaguar + BlackJagBridge plugin errors Shinigami2057 CAN 1 06-02-2010 11:20
