Go to Post I'm a drive team coach, they don't eat lunch during competition. - Rick [more]
Unread 18-10-2010, 21:02
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
MOving toward a circle with camera code
Hello all,
I am trying to make a robot move toward a circle, then when it's close enough, it kicks, shooting a ball into the goal.
How do I do this?
Thanks
(I'm the new guy)
Unread 18-10-2010, 21:53
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Re: MOving toward a circle with camera code
I'm interested in this as well. Our team is thinking about switching over to JAVA and I was wondering how that would look like.
-Dustin Shadbolt
Unread 18-10-2010, 22:52
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I don't have the FRC Java tools installed to confirm this, but I believe there is a sample you can find in the new project dialog which shows this using the gyro and camera.
Eric Haskins KC9JVH
Unread 19-10-2010, 22:16
1 * 4 != 14
it doesn't go autonomously
Unread 19-10-2010, 23:35
AKA: Eric Haskins
I'm looking at the sample, and it appears it should track the target left to right, but not produce any forward movment.
The first thing to do is make it drive forward. The simplest way to do this is to change line 48 of CircleTrackerDemo to, where forward_speed is a constant representing the forward speed.
drive.arcadeDrive(forward_speed, output);
Once that works you need to make it stop. There are a few ways to do that, one way is to do something like this at line 127 of the same file:
if (targets[0].m_yPos > someValueToIndicateHeightOfTheTarget)
OR
if (targets[0].m_majorRadius > someValueToIndicateTheSizeOfTheTarget)
when ... is
    //do stuff other than drive.
else {
    turnController.setSetpoint(gyroAngle + targets[0].getHorizontalAngle());
You could expand this to use PID to slow down as approaching the target distance, back away if too close, etc, but that is more advanced.
Once you have this working you could make it run in autonomous mode by moving the contents of the else, starting at line 99 in the sample, into the autonomousPeriodic function at line 73.
Eric Haskins KC9JVH
Camera picture on Dashboard with default project code? neg0riz0r NI LabVIEW 2 18-02-2010 10:53
Moving Camera Servos With Joystick Button DWirth NI LabVIEW 7 26-02-2009 21:35
Camera not tracking with default code iTHOS=awesome C/C++ 3 09-02-2009 11:14
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
