Go to Post Remember success in FIRST isn't measured by the trophies. It's measured by the inspiration. - camtunkpa [more]
Unread 19-10-2010, 08:11
Re: Jaguar Non-FRC Firmware
Originally Posted by drakesword View Post
Also when we stopped sending data the controller continued with its previously set output (EVEN DISCONNECTED FROM 2CAN!)
This is the very reason, for FRC, you have to use the specified code. WE want all robots to stop at the end of a match or when disabled by the field controller.
Unread 19-10-2010, 10:14
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
In that case is there a way I can use the FRC firmware not on the cRio?
There appears to be a set of commands with trust appended to them. I tried useing these commands with FRC firmware 91 but no luck. Do I need to send the trusted heartbeat?
Unread 20-10-2010, 08:18
Bryant,
I would defer to David for any advice on those issues. Clearly, the Jag series of products is intended to have a wider customer base than FIRST.
Unread 20-10-2010, 10:23
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
You can only use FRC firmware with the cRIO and/or the FRC version of BDC-COMM.
Yes, a trusted heartbeat is necessary to keep Jags with FRC Firmware alive.
If this project isn't intended for an FRC robot, I would recommend not using the FRC firmware. The source code for regular BDC-COMM and the non-FRC Jag firmware is in the firmware development package you have downloaded. Looking at the BDC-COMM source will help you understand what frames need to go out in order to control the Jaguar in various modes.
I am not sure what is going wrong when you switch to firmware version 91. More details would be nice. What does the Jaguar do when it works? What does it do when it doesn't work? What do you expect it to do and how does it differ? Take note of LED states, motor actions, values read off of the Jaguar, etc.
I have tested version 91 myself using BDC-COMM and I have had no trouble setting up and using the various modes. Since you are using the 2CAN adapter I would try contacting someone from Cross the Road, they might be able to help with their own hardware.
If I had a serial port I would. But cant until I have access to one.
USB to serial adapters are cheap and they work with BDC-COMM. If you happen to have a Vex programming cable laying around, the USB to serial cable works great. You just need to make sure you select the appropriate COM port (other than COM1) when using them.
-David
Unread 25-10-2010, 11:30
AKA: Bryant
I figured out what the problem was.
The firmware I was loading wasn't the proper one. sure it was in the directory but it didn't function. Recompiled but first running the make clean then make and the firmware works properly
New Jaguar Firmware: Version 91 dyanoshak CAN 6 06-11-2010 13:25
New Jaguar Firmware: Version 90 dyanoshak CAN 3 24-03-2010 11:41
New Jaguar Firmware: Version 89 dyanoshak CAN 10 24-02-2010 10:10
Bricked black Jaguar after bad firmware update FRC4ME CAN 13 19-02-2010 16:52
FRC CompactRIO firmware upgrade help mole Programming 8 17-01-2009 18:46
