Go to Post That is definitely a question for the GDC. My guess would be no (but I am frequently wrong). - Mike Betts [more]
Unread 19-10-2010, 15:15
Lilgreenmonster's Avatar
Lilgreenmonster Lilgreenmonster is offline
FRC #0134 (Team Discovery)
Team Role: Photography
Lilgreenmonster is an unknown quantity at this point
Send a message via AIM to Lilgreenmonster
A Problem With Defaults??
I'm feeling pretty stupid....I was editing an object, i clicked off it for a second, click back on it, now i cant get the "Parameters" rollout to come back up when i click on it!
I recently had to restore my HD, so i lost all my preferences, but it wasnt an issue prior to restore
I'm trying to get it this to come up again
http://www.chiefdelphi.com/forums/at...d=128751564 6
Screenshot is what comes up when creating a new "Plane"
Jared Landry
Team 134/Discovery
Multimedia/Autodesk
Grad Year: 2011
http://www.sau53.org/net9/First
SPARTANS
Unread 19-10-2010, 20:22
MadeAtMidnight's Avatar
MadeAtMidnight MadeAtMidnight is offline
AKA: Carrie Asner
FRC #1625 (Winnovation)
MadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud of
Re: A Problem With Defaults??
If I'm understanding correctly, you want to change the parameters of the plane? Have you clicked on the modify button (the rainbow button) when you have the plane selected? You should then get parameters to adjust.
I hope this helps.
Carrie
League of Mothers founding member
"There are two ways to spread light; to be the candle, or the mirror that reflects it."
Edith Wharton
Unread 20-10-2010, 17:37
I hope this helps.
THANK YOU!
I feel like an idiot
Jared Landry
Team 134/Discovery
Multimedia/Autodesk
Grad Year: 2011
SPARTANS
Unread 20-10-2010, 19:38
AKA: Carrie Asner
You're welcome
There is no reason to feel like a idiot.... it seems like you should be able to right click on an object, see the object properties and change it from there, but that's not the way max works.
Good luck with the animation !
Carrie
Edith Wharton
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
Problem with Controller rzienta FRC Control System 1 22-01-2009 12:05
problem with TwoColorTrackDemo-v2 mahmosh C/C++ 5 20-01-2009 09:30
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Problem with OI / RC Jay Lundy Technical Discussion 2 29-03-2002 23:07
