Go to Post Starting projects is fun, easy, and exposes you to new things, but finishing them shows true character. - Greg McKaskle [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 20-10-2010, 08:49
Kettering's Avatar
Kettering Kettering is offline
read. set. rebound rumble.
AKA: Steve Smitka
FRC #3098 (The Captains)
Kettering is just really niceKettering is just really niceKettering is just really niceKettering is just really niceKettering is just really nice
[OCCRA]: VEX hanging time
We have a question regarding the amount of time the VEX has to be hanging once the match is over.
Does the VEX have to stay off the ground for a specific amount of time after the match?
Here's our example. Our VEX can lift itself up, but once we cut power to it, the gears start to go backwards, causing our VEX to slowly drop.
Unread 20-10-2010, 08:53
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: VEX hanging time
Question: We have a question regarding the amount of time the VEX has to be hanging once the match is over.
Here's our example. Our VEX can lift itself up, but once we cut power to it, the gears start to go backwards, causing our VEX to slowly drop.[/quote]
Answer:
The match is scored at the end of the Big Bot match. To be scored as a HANG you must be suspended at that time.
Hint: Mechanisms that travel "Over center" will not "back drive".
Mike Martus
[OCCRA]: Hanging bar Mike Martus OCCRA Q&A 0 13-10-2010 22:37
[OCCRA]: Hanging Bar Kyoshirin OCCRA Q&A 1 10-10-2010 20:27
[OCCRA]: 2008 OCCRA VEX Carpet Playing Field - Home Depot marccenter OCCRA Programming 1 06-11-2008 09:57
[OCCRA]: what time is the occra banquet? MatthewArthur OCCRA 3 01-12-2005 17:28
