Go to Post The robots that rise to the top will not be the ones that do everything poorly, but the ones that are breathtaking at one thing. Be that robot. - DampRobot [more]
Unread 20-10-2010, 16:22
Quick Stability / FBD question
I need to give a lesson on stability tonight, but it has been a while since I've done freebody diagrams.
Can you folks help idiot check me before I fill the students' heads with lies?
For BEST, they have made what is essentially a rectangle on PVC pipe casters - see beautiful figure 1. I'm going to model it as a point mass with two struts. They push it to move it, and it has a tendancy to tip over. I want to create a simple formula to determine whether a redesign will tip, before they actually design it.
To do this, I'm calculating torques about the far strut. I see 3 contributors:
F*d1 = The force imparted by pushing times the height of the push point.
N*d2 = The normal force (weight) times the horizontal distance from the strut to the center of mass.
0 = The friction force from sliding over the carpet. I'm not so sure on this one - I think it is zero because it is right at the tip point?
This gives me F*d1 < N*d2 to ensure static stability. However, F is limited by friction, so I limit it to N*u.
This gives me N*u*d1 < N*d2, which becomes d2/d1 > u
This simple formula is pretty grokable, but is it true? Or more specifically, is it true enough?
Thanks guys, and be nice... our mentors are all ECEs, marketers and psychologists.
Quick Question Kersten Pneumatics 10 03-04-2008 22:01
Quick Question 3 Minitruck1506 Chit-Chat 0 22-02-2006 16:21
Quick Question 2 Minitruck1506 Chit-Chat 0 22-02-2006 16:17
Servo Stability Heavy Stuff archiver 2001 1 24-06-2002 03:54
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
