Go to Post I don't understand why it should matter if your robot is 100% student built, 100% engineer built or somewhere in between. As long as you are Inspired (I word again) FIRST is getting its point and primary goal across. - [more]
Unread 20-10-2010, 16:57
Re: Configuring router as a bridge?
Originally Posted by EricVanWyk View Post
I'm not sure what it says on the KoP bridges, but a lot of routers label that port as "WAN/Internet" because they assume folk don't know what a WAN is
The WRT610N User Guide calls them Ethernet ports. I was just being lighthearted.
Unread 20-10-2010, 21:14
I don't know what part of the guide you're reading, but the actual WRT610N router I have in my hand prominently labels the port Joe was talking about with the word "INTERNET".
wireless bridge not connecting to router kennypu FRC Control System 6 20-01-2011 12:49
Setting up Router and Bridge from Reset el-zoroo FRC Control System 2 09-05-2010 01:37
problem getting wireless router/bridge talking sam3062 Programming 8 23-02-2010 16:36
Laptop/Classmate/cRIO/bridge/router wiring help ricechrisbtreat Programming 2 17-01-2010 08:58
Can not connect bridge and router wirelessly team877 Programming 4 08-01-2009 00:18
