Go to Post This is far more then any little school extracurricular, this is a FIRST Robotics Team. - onecoolc [more]
Unread 20-10-2010, 15:06
Mikesername's Avatar
Mikesername Mikesername is offline
meh.
AKA: Mike Dame
FRC #3044 (Team 0xBE4)
Mikesername is an unknown quantity at this point
Send a message via AIM to Mikesername
Configuring router as a bridge?
Hey, I'm missing my bridge at the moment and was wondering how I could configure another router to act as a bridge. I'm not too great at networks, and was wondering if anyone has any help to offer? Googling hasn't offered too much for me.
[ ballston spa robotics | www.team3044.com | team BE4]
Unread 20-10-2010, 15:33
Re: Configuring router as a bridge?
You can actually just stick the original router on the robot and plug the cRIO into one of the non-wan/internet ports and it will work just fine.
Unread 20-10-2010, 15:58
I'm pretty sure you meant non-wan/ethernet port :-)
Unread 20-10-2010, 16:25
I'm not sure what it says on the KoP bridges, but a lot of routers label that port as "WAN/Internet" because they assume folk don't know what a WAN is.
Have you gotten into the routers configuration yet? Once you can configure it to be on the right network (10.TE.AM.x), it is relatively straight forward.
Full disclosure: I pushed Mike towards chief delphi because I couldn't remember the way to do this over the phone.
Unread 20-10-2010, 16:57
The WRT610N User Guide calls them Ethernet ports. I was just being lighthearted.
Unread 20-10-2010, 21:14
I don't know what part of the guide you're reading, but the actual WRT610N router I have in my hand prominently labels the port Joe was talking about with the word "INTERNET".
Unread 20-10-2010, 23:29
I misread your post Joe, sorry.
You intended non-wan/internet to mean !(wan/internet).
I read it as (!wan)/internet.
The (!wan) ports are Ethernet ports.
Does he have to change the IP address of the router on the robot to 10.xx.yy.1, or should he leave it 10.xx.yy.4 ?
Unread 21-10-2010, 01:03
It does not matter.
Unread 21-10-2010, 08:11
meh.
AKA: Mike Dame
if the router is connected to the cRIO this way, will it wirelessly connect to the driver's station or will it have to be tethered?
Unread 21-10-2010, 09:04
I was assuming from your original post that you wanted to use another router to replace the missing bridge on the bot, leaving the original router in place (connected to the Classmate) for wireless operation.
I guess what's being suggested here is to move your router to the robot, instead of adding another router, and use the Classmate's wireless card. That's why Joe said the router's IP address need not be changed.
I don't know about the Classmate and the WRT610N, but the router I have here at home for our wireless network has a better signal than the typical laptop wireless card.
Unread 21-10-2010, 09:25
The Driver Station does not have the capability of using 802.11n Wi-Fi on the 5 GHz frequency band. The "official" configuration of the WRT610N router has the 2.4 GHz frequencies disabled. You will have to modify the wireless settings on the router to enable 802.11g at 2.4 GHz, setting an appropriate SSID. Once you do that, the Driver Station (and any other 802.11b/g devices) should be able to connect to it wirelessly.
Unread 21-10-2010, 15:40
meh.
AKA: Mike Dame
Okay, I was just checking to see if that was what he meant. Sorry for adding confusion, but I did mean that we have two routers (one connected to classmate, one that would like to be a bridge). So it's just as easy as plug it in then? And configure it to have the settings the bridge would have?
Unread 21-10-2010, 19:34
I don't think the WRT610N router has a setting to turn it into a wireless bridge. The easiest thing is probably to use it on the robot as an access point, suitably configured so that your Driver Station computer can connect to it over Wi-Fi.
Some other routers do have wireless bridge modes, and there are third-party firmware images available for many popular routers which add that option.
wireless bridge not connecting to router kennypu FRC Control System 6 20-01-2011 12:49
Setting up Router and Bridge from Reset el-zoroo FRC Control System 2 09-05-2010 01:37
problem getting wireless router/bridge talking sam3062 Programming 8 23-02-2010 16:36
Laptop/Classmate/cRIO/bridge/router wiring help ricechrisbtreat Programming 2 17-01-2010 08:58
Can not connect bridge and router wirelessly team877 Programming 4 08-01-2009 00:18
