Go to Post Once again, my schooling is interfering with my education. - Caleb Fulton [more]
Unread 10-10-2010, 17:15
Re: pic: Broken Output Shaft
Originally Posted by mplanchard View Post
You have a large aspect ratio in this problem - long shaft and short, small keyway.
What keyway?
Unread 11-10-2010, 08:33
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
sorry - tried to answer this on my iphone. maybe it is a grove?
Unread 20-10-2010, 17:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Learning how to use COMSOL 4.0 at work (an excellent FE program for those who are interested, much better than COMSOL 3.5) I decided to see if it could show the stress risers in this particular situation, and it did so quite well. I've attached two plots. One plot is of the surface stresses, which does indeed show the stress concentrations in the groove. However, I find the slice plot much more illuminating as to why this groove is a stress riser. If you look at how the shear stress flows through the part you can see that it likes to stay near the outside surface, but the snap ring groove abruptly forces stress towards the middle, compressing the stress (if you will) around the groove.
Pay no attention to the magnitude of the stresses, I just picked a load number out of the air that was close-ish.
PS- I hope no one is too upset about reviving an older thread.
Unread 21-10-2010, 14:00
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Stress plots posted above.
Unread 15-11-2010, 20:47
kibbs425 kibbs425 is offline
AKA: Kyle Henry
FRC #0125 (Nutrons)
kibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to behold
Send a message via AIM to kibbs425
No FEA is necessary. Contrary to popular belief. A lot of good analysis can be done with a book, pencil and a napkin! All good ME design books will have a reference to Stress concentrations. They are generally relatively simple to use as long as you can read a chart.
Engineers edge (www.engineersedge.com) is the 1st pass that I usually take when I'm looking and I don't have my book handy and the internet is available. Here is the section on stress concentrations: http://www.engineersedge.com/calcula...tion-shaft.htm
This won't give you the stress unless you know the rest of the numbers, but you can at least compare Kts for the known geometry to determine what has less of an impact.
Shigley's Mechanical Engineering Design is my text book of choice. It was required in my college ME Design class. It is still something that I use regularly and has a lot of great references.
Good luck!
Since 2002
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
