Go to Post The term defensive robot and mechanum wheels do not belong in the same sentence together. - Koko Ed [more]
Unread 20-10-2010, 17:45
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Wireless not working
We have a WP-600N and WP-610N (the "WP" could be wrong but the numbers arent. This is the veteren router and adopter)
We have been following the steps in the 2010 Manual but it would not work. Can someone write down the specific steps or give us a link online as to how to do it.
Team 1514
Whcirobotics
Unread 20-10-2010, 17:57
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Wireless not working
The steps in the FRC manual, if followed correctly, should work. Can you be more explicit as to what is not working, and what lights you are seeing on your driverstation? That will help.
Unread 20-10-2010, 18:11
Router is WRT610N
Radio/Bridge/Game Adapter is WGA600N
Unread 20-10-2010, 18:35
FRC #1514 (Vikings)
What should the ips of the Router, Adopter and the C-Rio be? Because right now it shows a conflict but i checked and i do have have any ips matching each other.
Unread 20-10-2010, 18:57
10.xx.yy.4 WRT610N Router
10.xx.yy.1 WGA600N Gaming Adapter / Bridge / Radio
10.xx.yy.2 cRIO
10.xx.yy.5 Classmate
Unread 20-10-2010, 19:11
FRC #1514 (Vikings)
10.xx.yy.2 cRIO
Does the settings have to be 5ghz or 2ghz.. Right now it is set to 5ghz and is not working. Maybe try to do it with 2ghz? :S
Unread 20-10-2010, 20:00
Try opening a browser on your Classmate and entering 10.xx.yy.4 in the address box and see if you get the router's login screen.
Try entering 10.xx.yy.1 and see if you get the Game Adapter's login screen.
Unread 20-10-2010, 21:48
FRC #1514 (Vikings)
When I go on the browser and go to 10.15.14.4 it does open the lynxys screen. But the 10.15.14.1 does not open. There is some problem with that..
Just making sure:
10.15.14.4 is suppose to be Game Adapter, isnt it?
and 10.15.14.1 is suppose to be Router/ Modem?
Or i got it wrong?
Unread 20-10-2010, 21:52
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
It is the opposite, whcirobotics,
10.*.*.1 is the gaming adapter
10.*.*.4 is the router
Unread 20-10-2010, 21:54
FRC #1514 (Vikings)
O .. i will try this in school tomororw and get back to you guys if it works
Thanks
1514
Unread 20-10-2010, 23:15
Just making sure:
Or i got it wrong?
http://www.chiefdelphi.com/forums/sh...72&postcount=5
Unread 21-10-2010, 07:11
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Do the security keys match in the router and game adapter? If the game adapter has not been used since your last competition it has the event security key programmed into it. Easiest approach is to do a factory reset of both router and game adapter, and then follow the manual.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 21-10-2010, 08:51
If 10.15.14.1 does not work, try 192.168.1.250 and see if that works.
If it does, log in and change the IP to 10.15.14.1 Check the other settings too to make sure they're correct: follow the instructions in paragraph 2.10.1 of this document:
http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf
Unread 21-10-2010, 18:30
FRC #1514 (Vikings)
I got it working.! I do not know how but i set the ips to what u guys told me and still did not work. I was working on it at lunch and the lunch ended so i left to go to class. At the point it was NOT working. I came afterschool to try to fix it and ..... i just plugged it in and it started working :S i dont know why it wasnt working before but it is working now..
Thank you everyone for helping Much appreaciated
team 1514
Whci Robotics
Unread 21-10-2010, 22:39
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Gotta love technology's amazing self-fix powers.
wireless bridge not connecting to router kennypu FRC Control System 6 20-01-2011 12:49
Wireless bridge is not working (50% of the time) Phoenix Spud Control System 4 30-01-2010 10:19
Wireless not working after competition paulcd2000 Control System 6 09-07-2009 19:50
Wireless bridge not allowing IP change Lord Byron FRC Control System 6 15-01-2009 17:55
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
