Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread 16-10-2010, 22:21
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Birth of an Android App!
Originally Posted by rtfgnow View Post
Once you have that and some programming experience you will be able to sell apps. Some companies might try to hire you to make apps for them.
And with apps becoming more and more common these days, that's definitely a good goal to strive for.
Unread 17-10-2010, 13:48
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
Can we get some pictures?
Also (just curious) did write it in Java, or did you use app inventor? I don't know if app inventor is powerful enough to do what you have, since I program for iOS and not Android, but the concept of being able to create apps via an intuitive interface is a cool idea.
Follow me twitter dot com slash frc zach
Unread 17-10-2010, 14:32
Chris is me's Avatar
AKA: Pinecone
Originally Posted by ichisato View Post
I am definitely considering using adSense instead off charging $1 but I have to figure out the legality of that as well.
If your parents collect the revenue, then they can do whatever they want with it, such as give it to you.
However, do consider that your app essentially takes TBA, takes their ads off, and replaces them with your own. I would definitely talk to their development team and make sure that's okay.
Unread 17-10-2010, 16:15
ichisato's Avatar
ichisato ichisato is offline
Web Dev Chair - Team 1089
AKA: Nick :D
FRC #1089 (Team Mercury)
ichisato is an unknown quantity at this point
Nah, I programmed it in java.
I don't believe there is an 'app inventor' for android.
I mean, there's an interface "viewer"/form designer styled thing but that just (poorly) writes xml for you.
Unread 17-10-2010, 16:34
There is. http://appinventor.googlelabs.com/about/
Unread 17-10-2010, 16:59
synth3tk's Avatar
AKA: David Thomas
There is (Austin posted it above me), but for the purposes of this app, you're better off writing it the way you did. The App Inventor is a bit limited in what it can do, though it is very cool nonetheless.
Unread 17-10-2010, 21:43
ichisato's Avatar
AKA: Nick :D
I saw :C but, Really?
It's just my opinion, but I hate things like that >_<.
Kinda takes away from the glory of being a programmer (Lol, conceit), although, it is limited... and doesnt "allow for much logic" (yeah, i googled it).
Unread 17-10-2010, 22:48
synth3tk's Avatar
AKA: David Thomas
Eh, it's a great place to start for those that aren't programmers. I first learned PHP/HTML/CSS by playing around with forum and CMS software. Same thing can happen with App Inventor.
As I stated, you're better off just programming it in your IDE/whatever. By the way, I'm not a fan of GUI programming either.
Unread 20-10-2010, 15:10
ichisato's Avatar
AKA: Nick :D
QFT!
ALSO, THE APP IS NOW FREE - I talked to the owner of TBA and he didn't mind, but he did give some good points, and I've decided to make it free .
The updates/new features are still promised!
Unread 20-10-2010, 22:00
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
thank god, I was still waiting on my PO to be approved
Unread 21-10-2010, 14:01
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
I may be a bit biased, but whatever.
I'm glad you decided to make the app free. In its current state, it certainly isn't worth $1 in my eyes. I actually found TBA's mobile site easier to navigate and faster to load.
Consider this some constructive criticism...
  • Your app has a big problem with scrolling, in that most of the time it doesn't work on my phone. When I loaded the matches for an event, I had trouble seeing more than what was on my screen. When I actually got it to scroll down, I couldn't scroll up anymore.
  • It also does not behave as I'd expect with respect to the back button. The standard behavior for the back button is to take you back one screen, not exit the app. You should not have a separate "soft" back button in your app, use the one that's already on the phone, that's why it's there.
  • For the limited amount of information that you're showing on the screen, the user should not be forced to scroll left & right.
  • Put the team search box & button on the top of the screen so the user does not have to hit the back button to get rid of the soft keyboard in order to click the search button.
  • The ">>" button on the team page has no implicit meaning. How do I know that it will take me to the event results?
Android App - FRC Spyder Mike Soukup General Forum 58 08-01-2014 07:31
FRC Breakaway App tortugatortilas General Forum 0 23-01-2010 03:09
Android Java Team 1708 Dave Java 2 18-01-2010 22:35
How to build an android Ameya Chit-Chat 0 24-04-2002 14:33
