Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
Unread 21-10-2010, 18:56
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Question Chainless Mecanum Drive
Our team is looking into trying out mecanum wheels in an off-season competition. Due to time constraints and not wanting to have to mess around with chain, we were wondering if it is possible to have a chain-less mecanum drive. If so, how do we do this? Pictures or diagrams would be great. We are using standard Andy Mark mecanum wheels and the Andy Mark gear boxes. Thanks for your help
(On a side note, as I was looking through the forums researching mecanum drive, I saw some posts mentioning nona drive. However, I wasn't able to find an explanation of it, or any pictures. What is it?)
Unread 21-10-2010, 19:03
whackedwatchdog whackedwatchdog is offline
FRC #3224 (LHS)
whackedwatchdog is a jewel in the roughwhackedwatchdog is a jewel in the roughwhackedwatchdog is a jewel in the rough
Re: Chainless Mecanum Drive
http://www.andymark.com/searchresults.asp?cat=215
That (should be) the link to the "hubs" section of the andymark.biz site. You're going to want to find the size that coincides with the size of your output shaft/key. I wasn't actually around when we got them in and put them on, but unless I'm mistaken, you slide it over the output shaft, and the outer holes correspond to the (long) bolts on the inside of the wheels. There might be another part necessary to keep it on the output shaft, but that would be a good starting point.
(Someone correct me if I'm wrong, I had already left for college when they got everything together.)
Unread 21-10-2010, 19:04
Nonadrive (or Neunadrive) is 4 traction wheels, each in a pod with an omni wheel, and a fifth omni wheel in the middle at right angles to the rest. The pods rotate, allowing for traction or agility as needed. Used by 148 and 217 this year.
Unread 21-10-2010, 19:11
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Chain-less Mecanum:
Use AndyMark Toughboxes or Toughbox Nano's and mount the mecanum wheels on a hub, directly on the axle. Works well. Many teams that I saw did this (most mecanums I saw were direct drive), although I have no specifics. If you look at AndyMark's website, they have a drivetrain kit for 4-wheel direct-drive mecanum with toughboxes.
Nonadrive:
The creation of teams 148 and 217 (Robowranglers and Thunderchickens, respectively), it is a 9-wheel drive system essentially a convertible slide drive. Here is how it works:
There are four omni wheels on the perimeter of the robot, driven in standard tank drive. Each wheel is on a "pod" with a high-traction wheel, and the pods are pneumatically moved so the traction wheels can either provide traction or float above the ground.
In the middle there is a single omni wheel, driven by a single CIM, which is sideways (to cross the bumps, 148 and 217 pneumatically lifted this wheel a few inches to give them the center clearance necessary to cross the bumps).
This provides the "standard" amount of power (4 CIM's, or around 1.2 kw) in the forward/backward direction, while allowing non-pushing motion sideways. Since omni wheels are push-able, they can lower the perimeter wheels to push or avoid being pushed.
Kettering Motorsports
Unread 21-10-2010, 19:15
BJC's Avatar
BJC BJC is online now
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
The nonadrive is the pretty much the coolest new drivetrain in FIRST. It has the traction of a 4 traction wd (normally not used because it can't really turn) and the manuverability of a slide drive (normally gets pushed around alot in the heat of compitition). However, Its arguably on the level of complexity with a crab drive, so its not for the faint of heart. Definatly an offseason project.
lol, beaten to it.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 21-10-2010, 20:21
Direct drive mecanum is trivially easy. You just need the appropriate reduction in your gearbox for the size of wheels you're using. Like this.
Unread 21-10-2010, 21:16
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We designed a chainless mechanum chassis as a mental exercise during the summer of 2008. Included suspension. We never built this design.
Here's the link:
http://wiki.team1640.com/index.php?title=Mecanum
Cheers,
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 21-10-2010, 22:04
FRC #2635
Thanks! How heavy is a standard nonadrive? Five motors, 9 wheels, and four pneumatic cylinders, that must add up...
Unread 22-10-2010, 00:02
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
We learned this the hard way. During Overdrive we tried a mecanum drive and our robot would not move. At first it was thought to maybe be a code issue but turned out to be that our gear boxes (stackerboxes) were not geared down enough to move our robot.
Unread 22-10-2010, 00:22
Chris is me's Avatar
AKA: Pinecone
Not to take away from innovation and technical achievement, but I don't really see the Nonadrive as some kind of new Holy Grail in FRC drivetrains, and it is absolutely not something a team without the engineering resources to design a direct drive mecanum drive should do. It's not exactly a cheap, light, or simple drivetrain.
Unread 22-10-2010, 00:58
FRC #2635
So if we're using the 6 in mecanums, what is the appropriate gear box reduction?
Unread 22-10-2010, 01:06
12.75:1 seems to be a reasonable compromise between speed and torque (more or less depending on the game, of course)
Just curious, can you share a bit with us about your team's decision process that led you to your decision to explore mecanum wheels?
Unread 22-10-2010, 01:15
FRC #2635
Our main reason for trying them now is so that we have experience with them if we decide to use them for the FRC season. We bought them last year but decided not to use them for FRC because we didn't have any experience with them and we didn't think they would work well on the ramp. We want to learn how to use them because they are one of the most manueverable drive trains. From what I saw at the Portland regional last year the teams that used them were able to position themselves very well with the ball and goal and ended up doing pretty good. Basically, we think that they could be advantagous in this years competition and we want to be able to use them if they are.
Unread 22-10-2010, 01:21
On a sheet-metal chassis, which can be lighter than a more standard box-tubing chassis.
For further questions on the Nonadrive, you might want to take a look at the following two threads (and yes, there are two, one for each team that used it): 217 and 148--and definitely watch the videos that open the threads. (Warning: watching said videos may cause a sore jaw, due to said jaw hitting computer, desk, or floor.) Unfortunately, I can't seem to find tech specs...
But I do know where CAD files can be found!
To echo what Chris said, you need to know what you're doing to try a nanodrive. They'd have had a hanger on their robots in competition if they hadn't decided to reinforce their drive and make other improvements--and that's another scary part, they improved it from the videos.
Unread 22-10-2010, 01:34
The key words in this statement are: "could be" and "if".
Right now is a really good time to do a mecanum drive as an offseason project. You get a chance for rookies to build a robot, you test out new technology, and you gain knowledge and experience.
But the problem is that when all you have is a hammer, every problem looks like a nail. When Kickoff shows up, you will be tempted to use mecanum, even if the game is reminiscent of 2002 (where high traction, great pushing and low maneuverability were great benefits). Trust me, you will be tempted.
So, what you do is you take your offseason robot and a competing drivetrain (say, 6WD drop-center, or a 4WD built from the Kitbot) and run them through a series of tests, either individually or against each other with an offense vs defense. Then you evaluate which is better.
I'll let you in on a little secret: 330 has had the capability to use mecanum drive since 2005; development/small-scale prototyping started around 2003, with a full-scale base during the 2005 build season (thanks to the Kitbot frame). The closest they've ever come was 2009 with a turning 6WD system in the middle of their robot. The only time they've used wheels with rollers in competition was omni wheels in 2010, for added agility on a 4WD. They just haven't found it advantageous to use them...yet.
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Mecanum Drive Train Sam2197 Technical Discussion 25 16-11-2008 20:51
mecanum drive system Charger_07 Technical Discussion 5 23-01-2007 19:20
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
